Dear All,
For my project I really need some help. I want to run some dry tests before building further with my car project.
For this project I need some components on a breadboard. My skill in programming is better than building advanced electronic circuits. This is the reason why I ask you to examine my components and discuss if this combination will work without problems!
So when I order it and receive the items I wont be disappointed when it doenst work!
Underneath is a list with components which I have choosen.
It is for a connection between a FT2232H and a Amel Atmega 644P. First I want to test my programming skills just on the Atmel and further on in the project I will try to program a I2C into the building blocks.
For the FT2232H I found the following socket:
For the USB FT2232H:
Module:
http://search.digikey.com/scripts/DkSearch/dksus.dll?Detail&...68-1030-ND
2 resistors for the I2C:
2 times resistor 10k
http://search.digikey.com/scripts/DkSearch/dksus.dll?Detail&....0KQFCT-ND
For the Atmel Atmega I have choosen for the folling materials:
Chip:
http://search.digikey.com/scripts/DkSearch/dksus.dll?Detail&...44-20PU-ND
Crystal 20Mhz:
http://search.digikey.com/scripts/DkSearch/dksus.dll?Detail&...me=X195-ND
resistor 10k
capacitor 0,1uF
http://search.digikey.com/scripts/DkSearch/dksus.dll?Detail&...78-5096-ND
2 times a capacitor 22pF
http://search.digikey.com/scripts/DkSearch/dksus.dll?WT.z_he...11A220JAR+
Test circuit to prototype:
http://www.micahcarrick.com/files/atmega8/tutorial_3/circuit.png
5 times a resistor 1k
http://search.digikey.com/scripts/DkSearch/dksus.dll?Detail&...00KQFCT-ND
5 blue LEDS (I dont know if they will burn bright with just a VCC as input):
http://search.digikey.com/scripts/DkSearch/dksus.dll?Detail&...me=P468-ND
It will be placed on a:
http://search.digikey.com/scripts/DkSearch/dksus.dll?Detail&name=922354-ND
With:
http://search.digikey.com/scripts/DkSearch/dksus.dll?Detail&name=B-24-1-ND
For connection to the breadboard
I hope someone on this forum is so kind to examine my choises and give me feedback if something is wrong.
Thank you in advance.
Module:
Chip:
Crystal 20Mhz:
resistor 10k
capacitor 0,1uF
With:
