FSM State assignment encoding question
Discussion in 'Homework Help' started by de1337ed, Nov 14, 2011.
  1. de1337ed
    Mar 6, 2011
    23
    I understand how to do output encoding for a Moore Styled FSM. Can you do output encoding for a mealy style FSM? And if you can, can someone show me an example as to how? Thanks.
  2. hgmjr
    Jan 28, 2005
    9,030
    214
    Have a look at this paper on the difference between moore and mealy.
    There are a number of other papers on these two powerful techniques out on the Internet.
    hgmjrr
  3. de1337ed
    Mar 6, 2011
    23
    Don't get me wrong, I thoroughly understand the difference. I'm just asking specifically about state assignments. We learned in class about output encoding state assignments with moore machines, and I was wondering if you could do the same with mealy machines.
  4. hgmjr
    Jan 28, 2005
    9,030
    214
    A programming problem can be tackled using either technique. The paper to which I linked illustrates the application of mealy and moore FSM to the same problem.
    hgmjr
  5. Georacer
    Nov 25, 2009
    5,151
    1,266
    I think that there is a problem of definitions here. You say that you have output encoding with the Moore model. I 'd say that you have state encoding, just like in the Mealy model.
    The fact that the state is the output in the Moore machine (and can be encoded in a sense) is coincidental.
    Why do you need to encode the output anyway?
