fsm sequence recognizer
Discussion in 'Homework Help' started by xmadmaxx, Jun 27, 2007.
  1. xmadmaxx
    Apr 22, 2007
    6
    Hi i need to design a sequential circuit that recognizes sequence 01010.
    I've drawn the state diagram that has 5 states but now when I want to get the current state/next state table I get like 10 possible outcomes for inputs 0/1. I can't get rid of any states, What am I supposed to do to get the K-maps right...
    I think I'm supposed to have like 3-bits(3flip-flops)... please help :(
  2. beenthere
    Retired Moderator
    Apr 20, 2004
    15,815
    283
    You might want to hit the books a bit harder. I count 5 bits in yoyr sequence.
    By what means were you planning on validating the bit sequence?
    Being a crusty old technician, I'd grab a logic manual and find chips to do the function...
  3. n9352527
    Oct 14, 2005
    1,198
    Post your state table please. It does require 3 bits for 5 states and only two possible transitions from any state.
  4. Papabravo
    Feb 24, 2006
    10,340
    1,850
    To recognize a sequence you don't necessarily need a state machine. You can do it with a shift register and a some gates. Whenever the pattern in the shift register is equal to the value you want, just have a gate which says so! The shift register recognizer is an fsm with 32 states and one output, by the way.
