FSM Question (Quick Check).
Discussion in 'Homework Help' started by jegues, Dec 9, 2010.
  1. jegues
    Sep 13, 2010
    735
    43
    See figure attached for problem statement as well as my attempt.
    I just want to make sure I fully understand the process of going from a state table to boolean functions for the given flip flops.
    Am I correct assuming that everything after 1001 is a don't care state?
    Did I obtain my functions for Y2,Y1,Y0 correctly? (They should be the functions representing the input of each D flip flop)
    Also, is my K-map to reduce Y2 correct?
    I just to reassure myself that I am infact doing things correctly.
    Thanks again!
  2. tyblu
    Member
    Nov 29, 2010
    199
    16
  3. jegues
    Sep 13, 2010
    735
    43
  4. blah2222
    May 3, 2010
    565
    33
    Procedure looks fine.
  5. Georacer
    Nov 25, 2009
    5,151
    1,266
    The function for Y2 is correct.
    If you feel comfortable about the way you filled your K-map, go ahead and use it. If you have doubts about your method, I suggest the following:
    You can transform the table by inserting w as a separate column. That will double the number of rows but will make the problem more obvious to solve. Of course any rows that aren't noted on the exercise are a Don't Care.
    You can take this state (on step 4) table as a template:
    http://forum.allaboutcircuits.com/showthread.php?t=44399
