I have a question, well the question is the question it self, i don't understand what they are asking for.
Question::
"In this part of the exercise you are to implement a Morse code encoder using an FSM. The Morse code uses
patterns of short and long pulses to represent a message. Each letter is represented as a sequence of dots (a short
pulse), and dashes (a long pulse). For example, the first eight letters of the alphabet have the following representation:
A .
B . . .
C . .
D . .
E .
F . . .
G .
H . . . .
Design and implement a Morse code encoder circuit using an FSM. Your circuit should take as input one of the first
eight letters of the alphabet and display the Morse code for it on a red LED. Use switches SW2-0 and pushbuttons
KEY1-0 as inputs. When a user presses KEY1, the circuit should display the Morse code for a letter specified by
SW2-0 (000 for A, 001 for B, etc.), using 0.5-second pulses to represent dots, and 1.5-second pulses to represent
dashes. Pushbutton KEY0 should function as an asynchronous reset."
are they asking me to the input (assuming S0,S1,S2) will be used to put in letters from A-H, then am i to display the pulses on the red led by having it flash, example for H it would blink for times, and for G, it would be on for 2* (1.5 seconds) then blink once. also they ask me to display the moorse code, it it just the red LED or do they wan't me to print A-H on the 7seg display.
i am unsure whats being asked. can anyone shed any light on it, thank you.
Question::
A .
B . . .
C . .
D . .
E .
F . . .
G .
H . . . .
