Front panel labeling
Discussion in 'The Projects Forum' started by Neil Groves, Oct 19, 2013.
  1. Neil Groves
    Sep 14, 2011
    125
    I have thought about this and am all out of idea's, I have adopted the photoshop method to produce my front panel layout which someone suggested last time I asked about this topic and it works very well, however I am stumped when it comes to providing the calibration marks for the front panel rotary controls, how do I get the Cal marks in the right place prior to actually glueing the template design to the panel so that the start of the rotation lines up with the start mark.....sorry not very good at describing this :)
    Neil.
  2. MaxHeadRoom
    Jul 18, 2013
    10,831
    2,500
    I have only used Photoshop in a limited way but not sure if there is a way to set degree's exactly?
    I usually use a CAD program which is very precise.
    Also to make a front panel, reverse engraved Lamacoid gives many options including various colours.
    Max.
  3. Neil Groves
    Sep 14, 2011
    125
    ok Thanks
    i'm going to make a pretty backdrop to the controls and manually make my cal points.
    Neil.
  4. GopherT
    Nov 23, 2012
    6,301
    4,020
    If you are creative, you may be able to use Excel with a radar graph or similar radial co-ordinate system.
    Once drawn, you can past it into the rest of your front panel image.
  5. ErnieM
    Apr 24, 2011
    7,435
    1,625
    I'm doing just this thing this weekend (a little home- OT for a work project) where I have some rotary switches to number the positions.
    My solution is always to use an engineering tool such as AutoCAD so the workspace is in real inch increments and I can rotate objects by exact amounts. So rotary switches with 30 degree spacing get hash marks at 30 degrees. Temporary layout lines are also used as "snap to" markings so text can be placed in the same relative places on each stop.
    While I'm blessed to have a copy of AutoCAD on hand I'm sure there is also some freebie open source program anyone can get and use for this.
  6. atferrari
    Jan 6, 2004
    2,663
    783
    For more than 15 years, up to now, always Corel Draw. There are tools allowing drawing circular masks, with degrees marks and text to suit.
    What I am not sure is about the techniques to "fix" the printed thing to the panel.
  7. ErnieM
    Apr 24, 2011
    7,435
    1,625
    I just buy 8 1/2 by 11" label paper (full sheet one label) and place that down. It helps to first put a blank sheet down to get white-white (the paper is slightly transparent).
    Then I cover it in a sheet of clear contact paper.
    PAC-TEK makes some boxes with a sunken area that work very wekk with this method.
  8. Wendy
    Mar 24, 2008
    20,772
    2,540
    I do something similar to the above, but I use carpet tape, which is extremely sticky, then the printer (laser printer in my case). To protect the paper I then use clear shelf paper.
    For text I just a labeler, they truly are a God send for hobbyists.
  9. strantor
    Oct 3, 2010
    4,302
    1,989
    Once upon a time, I removed an OEM pot label with 320 degree hash marks and numbers, scanned it, and returned it. Since then I have had that digital copy; I changed it up a bit to avoid any copyright infringement that might apply. I used it several times, and I would share it with you know, except I recently lost that HDD. Actually, I think I may have shared that file before on this site, not sure. If you search you may find it or something like it.
  10. MaxHeadRoom
    Jul 18, 2013
    10,831
    2,500
    Here is a before and after using Lamacoid.
    Max.
  11. THE_RB
    Feb 11, 2008
    5,435
    1,305
    Characterise your pots by testing. A lot of them these days rotate X degrees, but the actual resistive element is quite a bit less than X degrees, with largish dead zones at the end limits.
  12. Neil Groves
    Sep 14, 2011
    125
    call me nostalgic but I prefere the before version lol
    Neil.
