Going PC to PC it has to be a crossover cable, a normal cat 5 won't work. You can make em easy though so just splicing you could make one out of a cat 5. Just swap the Rx and Tx pins on one side. But research it because I haven't made one in a couple years.In my thinking attach the cable with the computes then you will transfer the one files from one PC to another PC..wish you best of luck...
I think the best you can do is to have an access with window 7. This window contains for high speed and I have some experience regarding this matter. I want to transfer my file from my laptop to my desktop but, I'm found out that my desktop just doesn't feel quite as easy and also it is very user friendly. Therefore,I am satisfied with this kind of window 7.Hello friends. what is the easiest way to transfer files from my acer laptop to my e machine desk top. lap top win 7 64 bit e machine win 7 32 bit.
Thank you.
Beat me to it electronis whiz.could network them using wifi or a patch cable. you should be able to just use normal patch cable because most newer systems have method of detecting and configuring them selves for crossover mode.
Most email servers have a limit of 25MB, which is pretty useless if you're trying to send medium-sized files from computer to computer. It would also take forever, if you're trying to run a backup.If you have an internet e-mail account, just e-mail the file to yourself.
If you read that in the context in which it was presented:25MB is hardly useless. That size typically allows you to send Word documents, spreadsheets, image files (.jpeg .bmp .gif, etc) web pages and multiple attachments. How else would I be able to share all of these files over my yahoo account?
A lot of pdfs, especially, exceed that limit. I once had a 300MB pdf I was trying to transfer, and for that type of thing 25MB email limits are pretty useless....which is pretty useless if you're trying to send medium-sized files from computer to computer.
I have NO probelm reading context. Neither do I take what you say out of context. I don't consider 300MB to be a medium size file. Most of the documents people work with are easily attached using web based e-mail. I've never had to transfer a PDF file between computers. Instead, I download them from the webste from which I orginally obtain them.DerStrom8 said:If you read that in the context in which it was presented:
You obviously don't work with large files enough to realize that 300MB IS, in fact, a medium sized file. Good for you--I imagine that makes things easier for you, that you don't have to struggle with large ones. However, it's not uncommon for people to have files that are several gigabytes in size. Those I consider large. Text files and image files are tiny in comparison, and if that's all you've ever had to worry about, congratulations.I have NO probelm reading context. Neither do I take what you say out of context. I don't consider 300MB to be a medium size file. Most of the documents people work with are easily attached using web based e-mail. I've never had to transfer a PDF file between computers. Instead, I download them from the webste from which I orginally obtain them.
I don't think you're in a position to know what I work with. But leave it up to you to speak of things you know nothing about. a 300MB PDF file would be about 700 pages. That's the size of a very thick book if it were printed. Throw all the tamtrums you want, but that's not a medium size file. For most file transfers, e-mail works terrifically.You obviously don't work with large files enough to realize that 300MB IS, in fact, a medium sized file..
Please take it easy Brownout, I meant no offense. I simply meant that it was relative--if you work with large files (in the GB range) frequently, 300MB is a medium sized file. If you work with files in the KB range, 300MB is large. I was in no way trying to demean your level of work, I was only trying to point out that if you worked with much larger files, as I have, you would understand my point of view about medium-sized files. It wasn't supposed to be insulting. The size of files you work with says nothing about your expertise. I am not throwing tantrums. To be perfectly honest, that's what you're doing. You're taking everything I say personally, and in a way it is not intended. A 700 page book is a large book, but that does not mean the equivalent in computer file format is a large file. 300MB is a medium-sized file compared to 10-gig files that I've had to deal with in the past.I don't think you're in a position to know what I work with. But leave it up to you to speak of things you know nothing about. a 300MB PDF file would be about 700 pages. That's the size of a very thick book if it were printed. Throw all the tamtrums you want, but that's not a medium size file. For most file transfers, e-mail works terrifically.
by Jake Hertz
by Duane Benson
by Jake Hertz
by Duane Benson
