hello everyone i want to know how to connect DAC to sound sensor i knew that i must put attenuator and low pass filter before that sound sensor please i want any details and the hierarchy of the blocks thanks
Amplifier goes after attenuator because otherwise the amplifier would have to be more powerful and then waste a lot of the power in the attenuator.
Headphones may be in the mV range but loudspeakers may require 10s of volts.
Can I just check if you are trying to output a sound or to measure one - you mention DAC and sensor which are contradictory.
