From blinking led to not blinking
Discussion in 'The Projects Forum' started by susannah, May 12, 2014.
  1. susannah
    Thread Starter Active Member
    Feb 14, 2010
    87
    I have coin battery powered circuit which has led blinking.
    I would like to stop that blinking and keep led on.
    How i can do that? Thanks
  2. MrChips
    Oct 2, 2009
    12,624
    3,451
    Connect the LED to the battery via a resistor.
  3. djsfantasi
    Apr 11, 2010
    2,900
    876
    Is this a pre-made circuit or one you made? I expect the former. In that case, there is likely a black blob somewhere, which is a custom circuit to make the LED blink.
    You can't change this without rewiring the whole thing.
    It could be a custom LED that blinks. You can't change this.
    A circuit to light an LED off a coin battery is as simple as a battery and holder, a current limiting resistor and a LED. Some circuits omit the resistor, as the batteries internal resistance is sufficient, as long as the Vf matches the battery rating.
    We need more information regarding your circuit to be more specific.
    susannah likes this.
  4. susannah
    Feb 14, 2010
    87
    Thanks.
    It's this:
    H2OhNo! ATtiny Dev Board / Water Alarm
    https://www.sparkfun.com/products/12069
    It can be probably possible using programming, but i can't do that.
    What kind of components i should connect between legs of that blinking led and my own led so my own led is not blinking?
  5. MrChips
    Oct 2, 2009
    12,624
    3,451
    Building an LED water sensor is not difficult even for someone with no knowledge of electronics. All that is required is a transistor and some resistors.
  6. djsfantasi
    Apr 11, 2010
    2,900
    876
    The LED on the board is controlled by the ATTiny-85 microcontroller. Hence, it is not as easy to convert.
    Off the top of my head, you could use the signal into the LED to drive a separate retriggerable monostable multivibrator circuit whose on time is longer than the LED blink rate.
    Anyone else?
    Edit: what MrChips said. Designing a water sensor is easier than modifyng the Sparkfun one.
