From a tactille switch to a normal push button (micro switch)
Trekdrop
Joined Apr 17, 2016
7
Should be no problem, they appear to be simple contact closure P.B.'s.
Max.
Can you please tell me how? And maybe you can answer my other question, I want to connect this board to a battery of some sort do you have any advice? I am looking for a rechargeable battery.
MaxHeadRoom
Joined Jul 18, 2013
28,698
Ideally you have to remove the board sw first and solder a pair of wires to the two contacts, the other end to what ever N.O. P.B. or?
You could use a LiPo battery for recharge and long life.
Max.
MaxHeadRoom
Joined Jul 18, 2013
28,698
Just wire a pair of conductors to the PCCT strips of the switch you remove and the other end to a N.O. P.B. etc
You can use a LiPo battery for long life and recharge.
Max.
Trekdrop
Joined Apr 17, 2016
7
Max.
Nice I will solder the two wires, do you think the electric wire from the micro switch can be attache to the board or de I need to get the power elsewhere?
MaxHeadRoom
Joined Jul 18, 2013
28,698
You can get illuminated P.B.'s that a clear mylar image or text can be printed on and placed under the front of the switch, different colours are available.
The alternative is to get something engraved with Lamacoid from any engraver, if they have the symbols you want.
Max.
bertus
Joined Apr 5, 2008
22,278
You could check the pins with a multimeter.
The larger version of the switch will be connected like this:
Bertus
Trekdrop
Joined Apr 17, 2016
7
Max.
Everything works great! Thanks for your advice.
One more:
I want to make the Bluetooth range better. I have a Bluetooth dongle. Can I some how put the dongle on the board ?
