hello friends i seek ur guidence in understanding this simple looking circuit
The transistor is a PNP type, so the base must be more negative than the emitter, for it to work.hello friends i seek ur guidence in understanding this simple looking circuit
beautiful answer this helped me lot to understand thanks..........now last thing that i did not understand about this circuit is why is that diode used at emiter........there is necessary supply at the base of transistor which makes it to conduct then what is the use of diode?The transistor is a PNP type, so the base must be more negative than the emitter, for it to work.
Since a silicon diode, is sitting at the emitter, then a voltage of 0.7v. will be dropped across it when conducting.
so looking at the base emitter loop, you can see that as you start from the positive side of the battery, you have a -0.7v across the diode, and another -0.7v. across the emitter base junction, so that requires the base voltage to be at -1.4v. min, in order for the transistor to start conducting.
The R1 and R2 form a voltage divider, as the variable resistor, (VR1) is made larger, then less positive voltage is at the divider, and the divider voltage becomes more neg, to cause the base voltage to become more negative, to the point it reaches -1.4v. with respect to the +supply, and then conducts.
If the buzzer is a DC buzzer, then the capacitor in the right side is used as a intermitten to turn the buzzer on and off with a possible damping effect, in a exponential manner.
if the buzzer is just a piezo crystal, then the capacitor is used to cause the piezo crystal to turn on and off intermittenly at a frequency to make it work as a buzzer.
As I stated in my earlier reply I still think the circuit is misdrawn. I believe the diode is intended to provide a charge path for capacitor C1 when +ve is present and is intended to go into its reverse bias mode so that all of the charge in C1 will be forced to power the piezo through transistor T1 when the power drops below the minimum voltage level as set by potentiometer VR1.beautiful answer this helped me lot to understand thanks..........now last thing that i did not understand about this circuit is why is that diode used at emiter........there is necessary supply at the base of transistor which makes it to conduct then what is the use of diode?
by Jake Hertz
by Duane Benson
by Duane Benson
by Jake Hertz
