frequency units
Discussion in 'General Electronics Chat' started by samjesse, Dec 15, 2009.
  1. samjesse
    Thread Starter Active Member
    Sep 14, 2008
    202
    Hi
    I ofter come across what seams to be a confusing issue.
    f = 1/2pi root(LC)
    vs.
    f = 1/root(LC)
    the 2 pi is missing in the second equation.
    does this mean the first is in Hz and the second is number of cycles per 360° rotation?
    thx
  2. KL7AJ
    Nov 4, 2008
    2,043
    292
    The second version is in "angular frequency" which is a bit more elegant for some analytical work.
    eric
  3. steveb
    Jul 3, 2008
    2,433
    469
    Yes, and traditionally the greek letter omega (\omega ) is used for angular frequency with units of radians/second, while  f is typically used for cyclic frequency measured in units of Hz=cycles/second.
    However, this is just tradition in physics/engineering, and it is best to clearly define it whenever frequency is discussed.
    I like to use the word "cyclic" to qualify frequency  f={{1}\over{T}}, where  T is the period. For many years I called  f frequency and  \omega angular frequency. However, if you just say frequency, it's ambiguous. However, the term cyclic-frequency makes it more clear.
    By the way, does anyone know of another term for cyclic-frequency. Since the day I decided to use this terminology, I tried to think of another word for it, but never found a better one. I often wonder if I'm missing another obvious choice.
