frequency to voltage converter?
Discussion in 'General Electronics Chat' started by nyx, Apr 24, 2008.
  1. nyx
    Apr 24, 2008
    hi,
    I'm looking for the simplest way of converting the output of an optical microsensor to a voltage. The sensor is used to determine the rotation speed of a small shaft by means of a disc with small slits... it's basically a square-wave output with a 'low' of 600mV and a 'high' of 1.8V... as the shaft rotates faster, the frequency simply increases...
    so what i need is basically a way to convert this change in frequency to a change in voltage...
    if anyone can point me in the right direction i'd appreciate it greatly :)
    thanks!
    Zaid Mahmoud likes this.
  2. mik3
    Feb 4, 2008
    4,846
    63
    Is the duty cycle almost 50% ?
  3. Wendy
    Mar 24, 2008
    20,772
    2,540
    The humble 555 can do it almost directly. You build a monostable that is capacitively coupled, and trigger it off the frequency after it has been squared up. You design the monostable for a duration just under the shortest period the freq will have. Integrate the output and you have it, super simple.
  4. Caveman
    Apr 15, 2008
    471
    If you are using a microcontroller, the timer inputs work great for this.
  5. beenthere
    Retired Moderator
    Apr 20, 2004
    15,815
    283
    If you can run down an LM2907 frequency to voltage converter, it should be what you want.
  6. guyromb
    Member
    May 5, 2009
    28
    I am sorry that im responding to an old message but it's connected to this subject.
    I would like to build a freq. to voltage convertor using 555 chip too.
    I built an fm system: transmit 1khz sound + receive it. I can hear the sound using headphones. However, I want to get this signal so i can turn on a Led or something. Moreover, the receiver is a simple radio fm receiver (audio output).
  7. Wendy
    Mar 24, 2008
    20,772
    2,540
    This is called hijacking, and is strongly discouraged at this site. Basically the mods would like you to start a new thread, though it is OK to refer to this one.
    A monostable, any monostable, will convert frequency to voltage. First, figure your maximum frequency, then calculate the period of this frequency. Use 90% of this number for the monostable duration. Have you read this?
    555 Monostable
    When I have a bit more time I'll show you were to take it from there, but the idea is to trigger the monostable every clock cycle.
  8. guyromb
    Member
    May 5, 2009
    28
    I am sorry.. my first time here :)
    So should i open a new thread? or it's ok if i will continue write here?
    I don't really understand how to use the 555 to convert frequency to voltage?
    I have a 555 oscillator on my fm transmitter for 1khz. I just need a circuit that can recognize this signal from the reciever: when i transmit this sound i want to get '1'.
    I can use operational amplifier to compare the volatages but first i need to convert the freq. to voltage but i don't really know how to do it (I can't find lm2917).
  9. guyromb
    Member
    May 5, 2009
    28
    Ops.. I think i got the idea. Tell me if I right.
    The 555 in the receiver will produce something that is smaller from 1khz (like 900hz) and it will go to the op. amplifier and it will compare the other freq. from the signal (1khz) ??
  10. Wendy
    Mar 24, 2008
    20,772
    2,540
    No, the output of the 555 (or any monostable) will be PWM. A simple RC intigrator will convert this to a DC voltage.
  11. guyromb
    Member
    May 5, 2009
    28
    I have found a circuit but i still don't really understand :)
    I give the 555 frequency of 1khz and it's changing his wave width? How does it helps? what should I do later to convert it to dc voltage?
    o and thanks for your help :)
  12. bertus
    Administrator
    Apr 5, 2008
    15,806
    2,389
  13. guyromb
    Member
    May 5, 2009
    28
    1khz :) you can see previous messages on this thread (page1)
    ty
  14. Wendy
    Mar 24, 2008
    20,772
    2,540
    Wrong circuit. Did you read the article I recomended? That is a 555 monostable. 555's are very open ended, they can do lots of jobs.
    The circuit you have displayed is an oscillator.
    Since I'm 3rd shift (10PM-7AM) it is my bed time.
    This is an RC intigrator (ie, low pass filter), taken to the nth degree. Feed the output from the monostable into it (say 1 or 2 RC stages) and you have something approximating what you want...
  15. guyromb
    Member
    May 5, 2009
    28
    The 1khz come from FM reciever.... (fm transmitter transmit 1khz sound)
    I just want it will turn on a led or something like that when there is a sound of 1khz.
  16. guyromb
    Member
    May 5, 2009
    28
    Thanks Bill.. I will try now to do it. I'm not sure what to do but i will try :)
  17. Wendy
    Mar 24, 2008
    20,772
    2,540
    Hehe, you want a bandpass filter, or something very close. Narrow it down (what you want), and you'll get help matching it.
    Do you want to zero in on 1KHz, or are you after a VOX (voice activated switch)? If it is the latter google VOX, you will be amazed.
  18. guyromb
    Member
    May 5, 2009
    28
    :D hmm first i want that the 1khz will work..
    Oh... The monostable circuit on the 555 datasheet is fine ? Beacuse on your circuit you need too many resistors and components :p
  19. guyromb
    Member
    May 5, 2009
    28
  20. Wendy
    Mar 24, 2008
    20,772
    2,540
    Lets see, 3 resistors, 2 capacitors, and a 555. Ever hear of TANSTAFL? Their Ain't No Such Thing As a Free Lunch. A favorite quote from Robert A Heinlien. Don't forget the resistor and capacitor combo on the output. Good luck! :D
    Very nice, but read my article and you find out why it won't work.
    Good night.
