Frequency to Voltage Converter LM2917 Circuit Setup
Discussion in 'The Projects Forum' started by simply_me, Jun 8, 2010.
  1. simply_me
    May 6, 2010
    50
    I'm attempting to convert a received signal frequency to voltage for a comparison/subtractor with the sent/original signal (I've a linear ramp oscillator). From the datasheet of the LM2917 f/v converter I know that Vout= Fin* Vcc*R1*C1.
    If my original signal is about 4.2V (Vp-p), to which Vout should I design the circuit?
    Ultimately, in the comparison stage, I need the voltage difference between the original signal and the one received (maybe I should have a subtractor?) in order to measure distance.
    Thank you.
  2. SgtWookie
    Jul 17, 2007
    22,183
    1,728
  3. simply_me
    May 6, 2010
    50
    Hi SgtWookie,
    Thank you for the link, I've actually looked at it before I posted (since I'm using Multisim, and it doesnt have the spice model). My question is different. I'm asking to which voltage should I design my circuit to be? I have a circuit from the datasheet that I think will do the job (Frequency to Voltage Converter with 2 Pole Butterworth Filter to Reduce Ripple). As stated above, I'm just not sure to what voltage should I design my circuit considering my later intentions (comparator or subtractor).
  4. SgtWookie
    Jul 17, 2007
    22,183
    1,728
    Better read the notes in the Spice model.
    Russ Kincaid, who made the base macromodel for the 2907, put a note in there about saturation at Vcc/2. I don't have any of these IC's, so don't know how accurate the simulation will be compared to the real thing. I do know that if your output gets too high in voltage, strange things happen that would not happen with a real device.
    The real 2917x has a 7.5v Zener diode in it. That puts Vcc/2 at 3.75v. I suggest that you plan on making your circuit so that the output from the 2917 does not go higher than 3.75v for your input frequency range.
    I don't know what else to tell you off hand.
    Download LTSpice, and try out the models.
  5. simply_me
    May 6, 2010
    50
    That might be a little problematic, since my output sawtooth wave is about 5.40V. In order to compare/subtract the two Vout from the LM2917 must be greater than that no?
  6. SgtWookie
    Jul 17, 2007
    22,183
    1,728
    You could use a voltage divider for your other input, or amplify the output of the 2917 using another opamp.
  7. simply_me
    May 6, 2010
    50
    Thanks, I'll start designing the amplifier
