frequency reader and dispay
Discussion in 'General Electronics Chat' started by lotusmoon, Jun 17, 2013.
  1. lotusmoon
    Jun 14, 2013
    203
    is there a device that will read frequencies from a variable 555 circuit and display them on a digital screen?
  2. ErnieM
    Apr 24, 2011
    7,436
    1,626
    That would be a frequency meter.
    I've used some Fluke handheld multimeters that have such built right in.
  3. GopherT
    Nov 23, 2012
    6,310
    4,031
    Yes, it is called a frequency counter.
    Some digital voltmeters can do this as an added function (Hz is usually the symbol on the function selector).
  4. lotusmoon
    Jun 14, 2013
    203
    Thank you for that, you can probably see the level of my experience.
    I am also looking for a screen that I can build into the finished circuit so as the pot is turned the frequency shows up on that screen. so anyone using it can play with the frequency.
  5. wmodavis
    Oct 23, 2010
    737
    150
    Yup! Frequency counter.
  6. bance
    Member
    Aug 11, 2012
    315
    34
    Here's a couple of links to frequency counters you can build......
    HTH Steve
  7. lotusmoon
    Jun 14, 2013
    203
    thank you all. I will research this
