Frequency of signals
Discussion in 'The Projects Forum' started by Cerkit, Feb 2, 2009.
  1. Cerkit
    Thread Starter Active Member
    Jan 4, 2009
    275
    Hi. I need to find a way to generate signals of different frequencies using the same circuit so that I can swap through them. Have considered using oscillator but can not find one with good range and plus the very good ones are only useful for a small variation in frequency. Need to swap through frequencies between range of 17000Hz and 50000Hz.
  2. SgtWookie
    Jul 17, 2007
    22,183
    1,728
    Are you looking to generate square waves, pulses, triangle waves, sine waves?
    For square waves and pulses, you could use a 555 timer with a few extra components.
    For triangle waves or sine waves, things get a bit more complicated.
  3. Cerkit
    Jan 4, 2009
    275
    Well square wave would be more desirable but I have been told I won't be able to get very good precision with the 555. I need at least 4 digit precision hopefully 5.
  4. eblc1388
    Nov 28, 2008
    1,542
    102
    With precision down to 5 places, that's down to Hz for 50,000Hz. Only a DDS generator can fulfill your needs.
    You can look up Google for "DDS frequency generator".
  5. Cerkit
    Jan 4, 2009
    275
    How precise could the 555 be?
  6. Cerkit
    Jan 4, 2009
    275
    DDS to complicated/expensive for the application required need simple and compact
  7. eblc1388
    Nov 28, 2008
    1,542
    102
    Your requirement is not specific enough. Can you give some examples of what is required?
    1. Do you want just several fixed frequencies inside the range of 20,000 to 50,000Hz or they are continuously variable?
    2. Do the frequencies needed be specific and spot on every time? e.g. 24,567Hz every time or anything from 24,560 to 24,570Hz be OK?
    3. Making your goal too ambitious just complicate the ultimate circuit design.
  8. SgtWookie
    Jul 17, 2007
    22,183
    1,728
    If you need 4 or 5 digit precision in that frequency range, then you need a crystal oscillator. You could build something in the MHz range, and divide it down using a microcontroller or other circuitry.
  9. Cerkit
    Jan 4, 2009
    275
    What other circuitry can I use to divide the frquency?
