frequency multiplier for ecg signals
Discussion in 'The Projects Forum' started by racquel, Dec 15, 2010.
  1. racquel
    Dec 15, 2010
    good day everyone.i just wanna ask something about the transmission of ecg signals. Ecg signals ranges from a very low frequency, therefore i want to use a frequency multiplier for this project. what frequency multiplier should i use so that the frequency will be be multiply up to the audio frequency for the ease of transmission.?thank you
  2. blueroomelectronics
    Jul 22, 2007
    1,758
    98
    You could record the signal to a WAV file for example then play it back at any rate you like.
    racquel likes this.
  3. t06afre
    May 11, 2009
    5,939
    1,222
    Sound cards are most often AC coupled and they have frequency range from about 10 Hz and up. Take a look here for design ideas. http://openeeg.sourceforge.net/doc/hw/sceeg/
    This is a EEG amplifier But still you may perhaps use the modulator approach
    racquel likes this.
  4. racquel
    Dec 15, 2010
    how about the frequency multiplier?
  5. beenthere
    Retired Moderator
    Apr 20, 2004
    15,815
    283
  6. #12
    Nov 30, 2010
    16,704
    7,354
    There is no such thing as a frequency multiplier chip for audio frequencies. It is a rather complicated process. I like the answers in post #2 and #4. There are ready made computer programs that can change the frequency, but they are computer programs, not a chip or two.
  7. hgmjr
    Jan 28, 2005
    9,030
    214
    Would you be satisfied with using the low frequency ECG signal to frequency modulate an audio tone? This is along the lines of what beenthere has suggested.
    hgmjr
  8. t06afre
    May 11, 2009
    5,939
    1,222
    What will that help as long as the soundcard blocks out lower frequencies. The bandwidth for an ECG amp should be 0.01Hz to 250Hz at least. I suggest the OP take a look at the MC1496 circuit used as AM modulator
  9. racquel
    Dec 15, 2010
    your comments will be great help for me,thanks a lot
