why Frequency for motor PWM is usually 18kHz to 20kHz range ? can it set to 31khz as well? because arduino micro controller PWM output frequency is fixed. i cannot adjust anything ~ right?
what did you mean by whatever frequency ?Use what ever frequency works.
what will be the effect to the motor or something else by changing the frequency? why we need to set a proper frequency for the PWM? Thank youThere is not that much difference between 18, 20 and 31kHz for PWM.
If 31kHz works for you that's ok.
by Jake Hertz
by Aaron Carman
by Jake Hertz
by Jake Hertz
