What does a Four Quadrant Multiplier mean? what other types of multipliers are there ?Originally posted by Papabravo@Mar 28 2006, 07:57 PM
The AD633 is just such a four quadrant multiplier.
[post=15550]Quoted post[/post]
Greetings karunanithi_pricol,Originally posted by karunanithi_pricol@Mar 13 2006, 04:31 AM
Hi Everyone
I have to design a frequency doubler circuit. In which the input frequency will be coming from a speed sensor(Hall effect) and i have to double the frequency with the same voltage level as the input.
* Input frequency range will be 0 to 100 Hz square wave
Can anyone suggest me a cost effective solution for this requirement?
Regards
Karunanithi.R
[post=14927]Quoted post[/post]
Or if that isn't possible, two OR'ed Hall Effect sensors.Originally posted by hgmjr@Mar 29 2006, 04:54 PM
This may be a bit of an oversimplification from what you originally requested but have you given any thought to simply doubling the number of magnets on the rotating entity whose speed you are trying to measure? If feasable, this approach would double the frequency without having to resort to the additional electronics.
hgmjr
[post=15598]Quoted post[/post]
RonH,Originally posted by Ron H@Mar 29 2006, 06:09 PM
[post=15599]Quoted post[/post]
Good point. I hadn't thought of that. But, I don't see how you can get a sinusoid from one magnet on a shaft, sensed by a Hall effect device. Has Karunanithi said that this is the case? It seems to me that you would need multiple alternating magnetic poles around the circumference of the rotating device in order to get some semblance of a sine wave.Originally posted by hgmjr@Mar 29 2006, 05:32 PM
RonH,
I considered the possibility of "or"ing the output of two sensors but I was not clear on how I would do that with two sinudoidal waveforms.
<snip>
hgmjr
[post=15600]Quoted post[/post]
Ronh,Originally posted by Ron H@Mar 29 2006, 07:23 PM
[post=15603]Quoted post[/post]
The four quadrants are from Cartesian Coordinates and are defined by the aritmetic signs of x an yOriginally posted by Mazaag@Mar 29 2006, 04:26 PM
[post=15589]Quoted post[/post]
Hi allOriginally posted by Papabravo@Mar 30 2006, 06:43 AM
Quadrant 1. x is positive, y is positive
Quadrant 2. x is negative, y is positive
Quadrant 3. x is negative, y is negative
Quadrant 4. x is positive, y is negative
There is such a thing as a two quadrant multiplier.
[post=15605]Quoted post[/post]
You could use an active bandpass filter.Originally posted by karunanithi_pricol@Apr 8 2006, 10:21 AM
Hi all
What about this idea?
Step1: I can convert sine wave to square (using IC4069 and passives)
Step2: I can capture the square wave frequency through controller and i can
double the frequency of square wave at the controller output.
Step3: I have to convert this square wave back to sinewave. Now the output sine
wave frequency will be double of the input sine wave frequency.
will this work out?
Can some one help to convert square wave to sine wave?
Regards
Karunanithi.R
[post=15968]Quoted post[/post]
Originally posted by Papabravo@Mar 28 2006, 06:26 PM
Then the analog multiplier, such as an Analog Devices AD633 is the ticket you need.
[post=15525]Quoted post[/post]
Would it be possible to post the schematic of your circuit?Originally posted by karunanithi_pricol@Jun 2 2006, 08:33 PM
Hi Everyone,
I have tried with AD633 for my application ; this circuit doubles the I/P frequency from (10-100Hz) to (20-200Hz) but the problem is I/P sine wave amplitude is constant 5Vp-p and the output sine wave amplitude is getting varied with response to the input frequency variation.
Can anyone suggest me a solution for this? ie how to maintain the amplitude of output waveform constant irrespective of I/P frequency variation?
Thanks & Regards
Karunanithi.R
[post=17476]Quoted post[/post]
Hi hgmjrOriginally posted by hgmjr@Jun 4 2006, 01:37 AM
hgmjr
[post=17480]Quoted post[/post]
This signal is going to be processed by controllers and it requires constant amplitude. Can anyone suggest me a agc/limiter circuit for my application?Originally posted by n9352527@Jun 5 2006, 03:46 PM
Rather than attempting to maintain a phase shift of 90deg across frequency (which is difficult), why not just amplify the output with some sort of agc/limiter to maintain the required 5V level? This is certainly an easier solution.
Why do you need to maintain a constant output voltage?
[post=17521]Quoted post[/post]
