Frequency Doubler
Discussion in 'The Projects Forum' started by karunanithi_pricol, Mar 13, 2006.
  1. karunanithi_pricol
    Mar 13, 2006
    19
    Hi Everyone
    I have to design a frequency doubler circuit. In which the input frequency will be coming from a speed sensor(Hall effect) and i have to double the frequency with the same voltage level as the input.
    * Input frequency range will be 0 to 100 Hz Sine Wave with +/-5V amplitude.
    Can anyone suggest me a cost effective solution for this requirement?
    Regards
    Karunanithi.R
  2. Papabravo
    Feb 24, 2006
    10,340
    1,850
    If the output does not need to be a 50% duty cycle square wave, an exclusive-OR gate with a single pole low pass filter on one input can be used to produce a pulse on each edge. The values of R and C will control the pulse width.
    I don't know if they make these parts anymore but a double edge triggered one-shot will also do the trick. The problem with these quasi-analog digital circuits is that the location in time of the trailing edge can not be accurately controlled.
    If you want to be really clever you could use a phase lock loop to phase lock a higher frequency signal to your input and then divide it down by the appropriate amount. This may not work well if the input drops to zero frequency.
  3. Papabravo
    Feb 24, 2006
    10,340
    1,850
    Attached is a drawing of a frequency doubler that works in simulation.
    Pulse width is approximately 0.693*R*C
    Hope this helps
  4. Mazaag
    Oct 23, 2004
    255
    Papa,
    Could you just give me a brief explanation of how the frequency is doubled in this circuit?
    I understand that the XOR outputs a 1 when inputs are (01, 10 ).
    Here is attempt on understanding this circuit.
    Lets say we have an input square wave of 100Hz. As the input goes high, we start charging up the capacitor. The output of the XOR will remain high ( inputs to XOR are logical 1 for input square wave & 0 for voltage across cap ) until the capacitor charges up to TTL high, then the XOR will go low ( 1 1 ).
    No further changes will take place until the input square wave drops down to low, causing the capacitor to discharge. The output of remains high ( 0 1 ) as the capacitor discharges, until the voltage across the capacitor drops below ttl high , causing the output to drop to low ( 0 0 ). The output will remain at this state till the square wave goes high, and the cycle repeats.
    (Papa, Did that make any sense ? )
    That means , if we want the duty cycle to be 50% , we have to adjust our RC such that the time it takes the capacitor to charge up to TTL high is equal to the timeperiod/2.
  5. Papabravo
    Feb 24, 2006
    10,340
    1,850
    Yes that is correct. The frequency is doubled because there are now two edges on the output for each edge on the input. If you want the duty cycle to be 50% for all input frequencies then you are out of luck with this circuit. Sure you can adjust it for one frequency but that's pretty much it.
  6. hgmjr
    Jan 28, 2005
    9,030
    214
    One way that you may consider is to take a frequency to voltage converter and then feed the voltage output from the F-to-V through an opamp with a gain of 2 and use the output of the opamp to feed a voltage to frequency converter.
    The two signal will not be locked together but the output of the v-to-f will be 50% duty cycle.
    Another approach that would be effective though a bit more involved would be to use a phaselock loop circuit with a divide by 2 in the feedback path.
    hgmjr
  7. karunanithi_pricol
    Mar 13, 2006
    19
    Hi Everyone
    Sorry for this, infact the input signal will be 0-100 Hz sinewave (instead of square) with +/- 5V amplitude.
    Can anyone suggest me a solution for this design?
    Regards
    Karunanithi.R
  8. Ron H
    Apr 14, 2005
    7,050
    657
    Doubling zero Hertz is easy. What's tough is doubling 1 cycle per year. You need to set a realistic low frequency limit.
  9. Papabravo
    Feb 24, 2006
    10,340
    1,850
    A full wave rectifier or a bridge rectifier will double the frequency, but it won't be a sine wave anymore. You did not say it had to be a sine wave out right?
    If it has to be a sine wave, an analog multiplier might do the job with the input signal tied to both multiplier inputs. The square of a sine wave contains frequencies at the second harmonic only. There are chips which work at RF frequencies that are designed to do this also. They are generally used to create signals beyond the range of traditional oscilllators, in the hundreds of megahertz to hundreds of gigahertz range.
    You could probably do it with a DSP, an A/D converter and a D/A converter.
  10. karunanithi_pricol
    Mar 13, 2006
    19
    Hi
    Since i am verymuch new to the controllers; i am looking for a analog solution. Minimum input frequency will be 1Hz.
    Regards
    Karunanithi.R
  11. Papabravo
    Feb 24, 2006
    10,340
    1,850
    Then the analog multiplier, such as an Analog Devices AD633 is the ticket you need.
  12. n9352527
    Oct 14, 2005
    1,198
    How does an analogue multiplier double the frequency?
  13. Mazaag
    Oct 23, 2004
    255
    "The square of a sine wave contains frequencies at the second harmonic only." from Papa's post
  14. n9352527
    Oct 14, 2005
    1,198
    Right. So it has to be a four-quadrant multiplier?
  15. Papabravo
    Feb 24, 2006
    10,340
    1,850
    The AD633 is just such a four quadrant multiplier.
  16. karunanithi_pricol
    Mar 13, 2006
    19
    Hi
    Thanks for the response, Analog multiplier can be used for higher frequencies(in Khz to Mhz) will this multiplier be accurate for low frequency(Max 100 Hz)?
    Is it possible to design this product using op-amp?
    Regards
    Karunanithi.R
  17. hgmjr
    Jan 28, 2005
    9,030
    214
    Here is the trigonometric identity on which papabravo's recommendation hinges.
    sin(2 ω ) = 2 [sin( ω ) * cos ( ω ) ]
    This identity states that the product of the sine of frequency ω and its cosine results in the doubling of the frequency.
    The challenge will be generating the 90 degree phase shifted version of your input frequency.
    hgmjr
  18. n9352527
    Oct 14, 2005
    1,198
    I've just realised that there are two ways to approach the frequency doubling through analogue multiplication. My initial understanding was that the relationship would be along the line of:
    sin^2(ω) = 1/2 [ 1 - cos(2ω) ]
    Where the resulting sinusoidal wave would have a finite offset and phase shift.
    Using the identity that hgmjr posted out above, there would be no offset and no phase shift but would require an exactly 90˚ input shift. I believe that an RC network can be used to shift the phase and the phase shift doesn't have to be exactly 90˚ to get an accurate frequency. The phase shift error does, however, affect the offset and of course the amplitude of the resulting waveform.
  19. Papabravo
    Feb 24, 2006
    10,340
    1,850
    As you suggest, these circuits are in the AD633 datasheet, including the use of an RC to produce the 90 degree phase shift. The data sheet suggests that the output has a flat response from DC to about 1 MHz.
  20. Ron H
    Apr 14, 2005
    7,050
    657
    An analog phase shift network that is 90 degrees from 1Hz to 100Hz is probably impossible, or at least very difficult, to implement. Here is a good reference.
