Frequency divider
Discussion in 'General Electronics Chat' started by anhnha, Jan 14, 2016.
  1. anhnha
    Thread Starter Active Member
    Apr 19, 2012
    776
    48
    Is there a frequency divider from flip flops that can generate a clock with an arbitrary number such as 20, 25 not just 2, 4, 8, 16, 32, 64,...?
  2. Brownout
    Jan 10, 2012
    2,375
    998
    Yes. You have to decode that counts that give you those ratios. For example, to get a divide by 20, you decode the binary value 10100. Use the output of the decoder to restart the count.
    anhnha likes this.
  3. cmartinez
    Jan 17, 2007
    3,698
    2,788
    I'm not sure, but you could obtain any number you like through the addition of any number that is a power of 2. Just like you can express any number using the decimal notation.
    anhnha likes this.
  4. cmartinez
    Jan 17, 2007
    3,698
    2,788
  5. anhnha
    Apr 19, 2012
    776
    48
    Thanks for the answers!
    Could you explain a bit more?
  6. dannyf
    Sep 13, 2015
    2,196
    417
    There are decimal counters.
    Also, shift registers can be configured as counters to any integer.
    anhnha likes this.
  7. Brownout
    Jan 10, 2012
    2,375
    998
    For a simple example, consider a divide by three circuit. The output will be zero, one, two, zero, one, two, etc. An output will be generated each time the counter reaches two, so that output would be used to reset the count back to zero.
    If you generate your divide by three using a two bit counter, there is no need to reset the count, it will be done automatically.
    anhnha likes this.
  8. anhnha
    Apr 19, 2012
    776
    48
    Do you mean that we use the reset signal of counter as the created clock?
    I see that the clock doesn't have a 50% duty cycle. How can I get a 50% duty cycle?
  9. DickCappels
    Aug 21, 2008
    2,773
    669
  10. anhnha
    Apr 19, 2012
    776
    48
  11. Lestraveled
    May 19, 2014
    1,957
    1,218
    What you are describing is generally called a "divide by N" counter. A common chip used for this is a 74193 (TTL logic) programmable up/down counter. You load in the divide by number and clock the down pin. Do a google search for a 74193 or "divide by N counter", for more info.
    alfacliff and cmartinez like this.
  12. anhnha
    Apr 19, 2012
    776
    48
    Yes, that will do the job but I don't want to use any chip. Maybe I just need to read the structure used in the chip.
  13. cmartinez
    Jan 17, 2007
    3,698
    2,788
    If that's the case, then I strongly suggest you download Digital Works. It's a free digital electronics simulator software that allows you to build logic layouts using the most commonly available gates and flip-flops to create any logic process that you want. And it's also an extremely powerful learning tool.
    Sinus23, atferrari and anhnha like this.
  14. Brownout
    Jan 10, 2012
    2,375
    998
    No. Use the created clock as the reset of the counter.
    Feed a flip flop configured as a 1-bit counter with 2X frequency you want (derived from the counter/decoder we discussed.) The f/f will divide the freq by 2 and guarantee 50% duty.
  15. Brownout
    Jan 10, 2012
    2,375
    998
    Once can use !BO for the generated clock (not 50%Duty Cycle) and also to reload the start value. Or, load MAX COUNT - count(frequency), count up and use !CO.
  16. alfacliff
    Dec 13, 2013
    2,449
    428
    if you dont want to use any chip, you will have to build the circuti with resistors and transistors. that will take up a lot of time and parts. that is why chips were invented, making building blocks that could be connected together to make anything you want.
