frequency divider circuit question
Discussion in 'The Projects Forum' started by jakoy00, Mar 19, 2009.
  1. jakoy00
    Mar 18, 2009
    can someone help me?
    how to make a frequency divider using TL071CP/TL072CP op amp?
    i got a schematic for this circuit but the component TL071ID is not available in my country.
    help pls?
  2. Ron H
    Apr 14, 2005
    7,050
    657
    That's not a frequency divider. It's a lowpass filter.
  3. Audioguru
    Dec 20, 2007
    9,411
    896
    I think the circuit is an oscillator. The 100k pot must be turned down to less than 2k ohms to avoid oscillation if the frequency adjusting pots are set the same.
    The circuit is a Butterworth lowpass filter if the 100k pot is set to only 600 ohms.
    Use a 1k pot.
