frequency counter
Discussion in 'Embedded Systems and Microcontrollers' started by onlyvinod56, Aug 20, 2013.
  1. onlyvinod56
    Thread Starter Active Member
    Oct 14, 2008
    362
    Hello.
    This is my first post under micro controllers section.
    I want to design an LCR meter using 89s52.(because i have that programmer).
    I need to measure the frequency generated by the opamp for the specific LC elements. I started writing a code. (attachment 1).
    I used timer 0 as counter. initialized TL0 and TH0; started TR0=1;
    It is tested with a clock pulse given to the T0 pin.
    I am not getting idea that how to stop the counter(TR0=0) for a given interval of time.
    for example, i want count a 1KHz pulses / 1millisecond. how to specify the 1 ms in code.
    To see the count i used an 16x2 LCD.
    code:
    Code ( (Unknown Language)):
    1.
    2. #include<reg51.h>
    3. sbit rs=P3^7;
    4. sbit en=P3^6;
    5. void lcdcmd(char value);
    6. void lcddata(char value);
    7. void delay();
    8. void main()
    9. {
    10. int x,a,b,c,d;
    11. T0=1;
    12. TMOD=0x05;
    13. TL0=0;
    14. TH0=0;
    15. while(1)
    16. {
    17.
    18. TR0=1;
    19. x=TL0;
    20.
    21. //while(TF0==0);
    22. //TR0=0;
    23. TF0=0;
    24. a=x/100;
    25. b=x%100;
    26. c=b/10;
    27. d=b%10;
    28.
    29.
    30. lcdcmd(0x38);
    31. lcdcmd(0x0e);
    32. lcdcmd(0x01);
    33. delay();
    34. lcddata(a+0x30);
    35. delay();
    36. lcddata(c+0x30);
    37. delay();
    38. lcddata(d+0x30);
    39. delay();
    40. }
    41. }
    42. void lcdcmd(char value)
    43. {
    44. P2=value;
    45. rs=0;
    46. en=1;
    47. delay();
    48. en=0;
    49. }
    50. void lcddata(char value)
    51. {
    52. P2=value;
    53. rs=1;
    54. en=1;
    55. delay();
    56. en=0;
    57. }
    58. void delay()
    59. {
    60. int i,j;
    61. for(i=0;i<=100;i++)
    62. for(j=0;j<=100;j++);
    63. }
    64.
  2. pavans2510
    Aug 27, 2013
    Hi Vinod,
    You can use another timer to generate an overflow interrupt (or WDT) for regular interval that you want then inside that interrupt you can start or stop the counter.
