Frequency counter
Discussion in 'General Electronics Chat' started by shreyas_bhat, Feb 5, 2005.
  1. shreyas_bhat
    Thread Starter Active Member
    Jul 26, 2004
    47
    Hey Folks
    was wondering if a Frequency counter, can count frequencies of only digital signals, or analog signals as well. I have an analog (sine wave) whose frequency is to be read. Is it possible to use a Frequency counter straight for this operation (if yes, which one) , or the signal has to be converted to a square wave first and then read using a counter ?
    Shreyas
  2. beenthere
    Retired Moderator
    Apr 20, 2004
    15,815
    283
    I think that as long as the waveform changes direction regularly, your counter will work with it. Freq counters were originally made to count analog waveforms.
  3. shreyas_bhat
    Jul 26, 2004
    47
    Hey BeenThere
    Thanks for the reply. Shall try rigging up the circuit now.
    Shreyas
  4. dragan733
    Dec 12, 2004
    152
    The signal has to be converted to a square wave vave. All modern Frequency counters are digital.
  5. 1000MFD
    Dec 5, 2004
    You sure about that, Dragon? Methinks u've a bit more learning to go.
