hey guys i need help with making a frequency counter circuit using a microcontroller and an lcd display dat shows corresponding frequency of a square wave upto 100mhz......source code will also b required to burn hex files on uController...thank u
9 orders of magnitude. Does that matter?Now, if you meant 100MHz, then you have a more challenging task.
Yes, considering that 100MHz is likely faster than the crystal frequency for the microprocessor.9 orders of magnitude. Does that matter?
actually i need both schematic as well as source code....and the counter shoud measure upto 100MHzSo just what are you asking for? Both a schematic and source code?
by Aaron Carman
by Jake Hertz
by Duane Benson
by Aaron Carman
