Frequency Converter
Discussion in 'General Electronics Chat' started by eng.zaid, Dec 14, 2007.
  1. eng.zaid
    Dec 6, 2007
    10
    I need to know how to convert a signal with specific Amplitude and Frequency to the same signal and amplitude but with other frequency that i determine it (i.e how to change a signal's frequency only).
    Thank
  2. beenthere
    Retired Moderator
    Apr 20, 2004
    15,815
    283
    No problem preserving/restoring the signal amplitude, but the frequency shift could be a challenge. Can you say how much the frequency shift is, and is it up or down?
  3. hgmjr
    Jan 28, 2005
    9,030
    214
    If you don't need the output frequency to be sinusoidal you could use a frequency-to-voltage converter the output of which you could feed into a gain stage or an attenuating stage and then feed the resulting DC signal to a voltage-to-frequency converter.
    If you need greater accuracy in freqency tracking then you would probably need to resort to a phase-locked-loop based design.
    hgmjr
  4. recca02
    Apr 2, 2007
    1,211
    how about something like VFD?
