freq generator that can set exact frequencies?
fawcetteng
Joined Dec 11, 2010
10
Looking to build a simple sine or square wave generator that i can know what frequency it is outputing. That is, either have a way to set the frequency "exactly", or have a built in frequency counter to display to me what the frequency is. I want to be able to accurately calibrate older automotive tachometers. Would really like the frequency accuracy to be less then 2hz (this equals 50rpm on a 4 cylinder auto). So the ranges I need are below.
If not easy to build, can someone point me to something on fleabay that would work, for no more then maybe $100?
square or sine pulses, +/- 5v or +/-12V, or 0-5 or 0-12V DC.
frequencies in the range of 133Hz to 600Hz.
SgtWookie
Joined Jul 17, 2007
22,230
Are you in the USA or Canada? If so, the AC is 60Hz. In most other places, it's 50Hz.
Once rectified, it's 120Hz rippled DC and 100Hz rippled DC, respectively. It's usually very accurate.
Would a single frequency like that be sufficient, or do you need a range of frequencies?
t06afre
Joined May 11, 2009
5,934
A sound card waveform generator may create a sinewave in that frequency range with a about 1 Hz accuracy I think. I guess you can find such tool free on the net. The output voltage range of a sound card will not be in your range. But a simple amplifier may take care of that.
I might be able to whip something up for you(windows os) if you do not find anything
bertus
Joined Apr 5, 2008
22,278
You can make an oscillator with an cd4060 and a 32768 watch crystal.
On the following outputs you will find the following frequencies:
Rich (BB code):
Pin  7 -> 2048 Hz
Pin  5 -> 1024 Hz
Pin  4 ->  512 Hz
Pin  6 ->  256 Hz
Pin 14 ->  128 Hz
Pin 13 ->   64 Hz
Pin 15 ->   32 Hz
See the attached PDF how to connect the crystal to the chip.
Bertus
debe
Joined Sep 21, 2010
1,390
Hi I find where i live the mains is 50Hz, using a small transformer steping the mains down to 6V ac gives 1500Rpm for 4Cyl & 1000Rpm for 6Cyl tachos. Found this acurate for calibrating tachos.
Wendy
Joined Mar 24, 2008
23,429
You could also build a simple freq counter (it has been done with PICs for lower frequencies) to set a simple oscillator. Depends on your application.
fawcetteng
Joined Dec 11, 2010
10
All great ideas - thanks for the help. I've found these older tachs, even with a good cleaning, are no longer linear, so setting them at say 1500rpm they can be as much as 500rpm off up at redline.
Using the sound card intrigues me. I assume a "simple amp" is some sort of op amp, a power supply, and a few resistors? Can anyone point me in the right direction to get amp up to 9 or 12v peak output from the sound card's output? I can write the software to output the sound wave.
Bill - I like your idea (and the watch crystal osscilator one), but dont know much about what you are talking about. PICS and osscilator. As a grease monkey/ME , dabbling in electronics I come here for specifics.
t06afre
Joined May 11, 2009
5,934
Components will be victim to ageing problems. Capacitors and resistors values will drift. Some capacitors may also dry out. Solder joints are prone to crack. So cleaning will not be enough in order to restore old electronics in most cases.
A typical opamp may deliver around 15 to 20 mA without problem. Will this be good enough for your setup. Or is more current needed in order to drive your tachs in your test bench
If you have experience with microcontrollers you could use a DDS (direct digital synthesis) IC. The one I'm using AD9834, has a enormous frequency range of up to ~37Mhz and 0.004 Hz accuracy. It can output sine, triangle, and square with the built in comparator.
This is probably overkill if you need a simple oscillator but if I finish my project sometime in the near future I can add it to this site to take the design stage out of the question. I'm trying to make a full out function generator out of it.
