Greetings,
I need someone to design and build for me a board to drive and control a hand-held device (for personal research purposes) that strobes an infrared LED bulb, and a small xenon, krypton, and (if possible) halogen bulbs. 1 of each.
Some features that I would like to include are 3 or so different sets of flash rate/ patterns. This device will be powered by batteries, and it should be able to run at least (but preferably greater) for 2 hours on a single charge, and have an auto-off at 15 minutes. And for size: something that winds up being basically the size of a garage door opener.
I have an existing LED device that does not strobe, but already has a plastic enclosure for the circuitry. I can have that modified for the above purposes (strobe/flashing settings + above listed bulbs), or would it be easier to start from scratch? Can all 4 of those bulbs be incorporated into the same board? I'm basically looking for the smallest (typical LED-size) and brightest bulbs that do not heat up too much and can be easily replaced when they burn out (not soldered on) as well.
I hope I explained the basic premise half-decently. Please PM/email me for more details and what you would charge me. If you cannot help, recommendations for who to contact would be much appreciated.
Thank you!
Thank you!
