I need someone to design and then construct what I am told should be a fairly simple board to drive and control strobed LED's. This is a component of a development project I am managing.
The initial unit will be designed so that certain values...flash rate, flash duration, sequence, and brightness level...can be adjusted in the field for testing. This device will be powered by batteries, so ability to calculate power usage and make recommendations regarding same will be needed. On/Off and brightness level will be controlled by a hand-held remote.
Please PM me for details and cost discussions.
