Free ISO image readers?
Discussion in 'Computing and Networks' started by spinnaker, Nov 22, 2012.
  1. spinnaker
    Thread Starter AAC Fanatic!
    Oct 29, 2009
    5,115
    1,195
    Can anyone recommend a good free iso cd image reader?
  2. bertus
    Administrator
    Apr 5, 2008
    15,809
    2,390
  3. t06afre
    May 11, 2009
    5,939
    1,222
  4. elec_mech
    Nov 12, 2008
    1,513
    193
    This one works well for me: http://www.imgburn.com/. It's easy to use and you can copy, create, and make modified images.
  5. tinamishra
    Dec 1, 2012
    39
    An ISO image is an archive file (also known as a disk image) of an optical disc, composed of the data contents of every written sector of an optical disc, including the optical disc file system. ISO images can be created from optical discs or from a collection of files by image creation software; images can be used to write optical discs. Software distributed on bootable discs is often available for download in ISO image format, and used to write a CD or DVD. ISO image files often have a file extension of .iso. The name ISO is taken from the ISO 9660 file system used with CD-ROM media, but what is known as an ISO image might also contain a UDF (ISO/IEC 13346) file system or a DVD or Blu-ray Disc (BD) image.
  6. takao21203
    Distinguished Member
    Apr 28, 2012
    3,578
    463
    Be careful. Some softwares can not extract ISO archives with long file names correctly. The extracted file tree will be corrupted, and for instance can not be used for installation.
  7. DerStrom8
    Feb 20, 2011
    2,428
    1,329
  8. btimage
    May 31, 2013
    a friend introduces rasteredge's image reader c# to me, seems pretty awesome. but i am not sure it processes ISO image or not. take a look i guess.
  9. electronis whiz
    Jul 29, 2010
    519
    27
    for a while I always used ISO buster, available in free version, but has limits. somebody told me about daemon tools lite and I switched to that. also iso buster you had to extract it before you could run an install. daemon tools you just double click the file and then you can open it in an emulated cd drive in my computer. when done eject the media from the drive then you can more iso, etc. else it will error out. seems faster than iso buster too because don't need to extract stuff that may not be needed. I had one occasion back before I changed that daemon tools may not be able to help. I have a 64 bit system, and due to other programs I had to install 32 bit version of combo ISO. it automatically defaulted to 64 bit so the extracted copy I had to go in and delete the 64 bit program then it worked. may be able to do in daemon tools, but haven't had to do that again yet.
  10. tshuck
    Oct 18, 2012
    3,531
    675
    I've used both PowerISO and MagicDisk quite a bit. Both are nice, but I'd probably prefer PowerISO for no particular reason :).
  11. BReeves
    Member
    Nov 24, 2012
    412
    64
