Free 19 inch Dell LCD for repair
Discussion in 'General Electronics Chat' started by maxpower097, Sep 29, 2010.
  1. maxpower097
    Feb 20, 2009
    795
    388
    You heard it, I'm in Tampa FL and have a Dell 19 inch widescreen LCD thats free to anyone wanting to repair it. At first you would plug it in and the blue light would just flash as if no signal. Then the blue light quit coming on. Its in mint condition with a nice stand. I'd hate to toss this thing in the dump if someone can repair it and have a nice LCD. PM me if interested. Not sure how bad shipping would be.
  2. tom66
    May 9, 2009
    2,613
    214
    I don't live in Florida so I couldn't collect it. In fact I'm on another continent.
    However, 99% of the time when the monitor will not come out of standby it is due to faulty caps in the PSU. Seriously give it a go - it'll cost $2 max to replace the caps, and you could have a working monitor by the end of the day.
  3. maxpower097
    Feb 20, 2009
    795
    388
    Whats a PS?
    j/k I may give it a whirl since it is a nice LCD then mine.
  4. tom66
    May 9, 2009
    2,613
    214
    PSU = Power Supply Unit.
  5. roadey_carl
    Jun 5, 2009
    116
    5
    Ive fixed 2 samsung lcd screens over the last 6 months! both had the same problem and I replaced the 100uf caps and they work good as new :D
  6. loosewire
    Apr 25, 2008
    1,584
    435
    I'm In Fla Is It still available.
  7. maxpower097
    Feb 20, 2009
    795
    388
    Ok I got the PSU out and I'm looking at it and I notice 3 Caps that look like they are bulging, or ballooning. The tops are rounded to a degree. Should I test em with the MM or just replace them? And it so happens they are the caps directly connected to a power plug showing B-DIM/+13v/+5.1v/A-DIM/O-F. The 3 caps in questions are
    1. Black KM105 c / C711/ VENT 25v 330uF
    2. Black CapXon 25v / 330uf
    3. Green 1000uF 16v
  8. andrew24
    Aug 20, 2008
    76
    just replace the caps with the new ones with the same capacity.
  9. tom66
    May 9, 2009
    2,613
    214
    Make sure to at least the capacitance. Make the voltage the same or higher. Go for good quality capacitors such as Panasonic or Rubycon.
    Can you post pics of the caps?
  10. maxpower097
    Feb 20, 2009
    795
    388
    One more issue. I notice what looks like white/yellow ish glue on amany of the disc caps. They look like the glue was intentionally put their for stability. Is this glue? Or are these caps popped and leaked all over the place? It really looks like rubber elmers glue. Pictures coming in the next 2 hours.
  11. tom66
    May 9, 2009
    2,613
    214
    It's glue. You find it in many power supplies.
    Be careful not to touch any high voltage caps. You may see one rated for 200V - be careful it may well have 200V across it (leave the monitor off for about a day before commencing repair.)
  12. maxpower097
    Feb 20, 2009
    795
    388
    Here are some pics of the suspicious caps.
  13. maxpower097
    Feb 20, 2009
    795
    388
  14. tom66
    May 9, 2009
    2,613
    214
    I can't read the cap values but if they match it should be fine.
    Those caps are definitely bulging and probably causing the failure.
    See the 450V cap? Be careful not to touch that. Use a multimeter to check the voltage.
  15. maxpower097
    Feb 20, 2009
    795
    388
    Yah the specs match. Could I go a lil higher for more protection or stability? And honestly what do you think the chances are that this is gonna fix it?
  16. andrew24
    Aug 20, 2008
    76
    you could definitely go a bit higher on the voltage of capacitors. But the capacitance must be the same
  17. tom66
    May 9, 2009
    2,613
    214
    For filter caps you should keep the capacitance the same, but you can vary it a little. You can't put a massive cap on the output because the LC filter will have been designed to cut down on one frequency and this will actually create more noise.
    Do note that the size of the capacitor varies with voltage rating. So you cannot put a 50V cap in the place of a 16V cap, simply because there is not enough space. But you may be able to fit a 25V cap in there.
    The cap voltage ranges are: 6.3V, 8V (sometimes), 10V, 16V, 25V, 35V, 50V, 63V, 80V (sometimes), 100V, 150V, 200V, 330V, 400V, 450V. (Those are the typical values I've seen, you'll find others but they are not common.)
  18. maxpower097
    Feb 20, 2009
    795
    388
    10-4 Thanks for the tip. Shipping from digi is really reasonable. I think they want $2.41 for anything under half pound. So I may get a good selection of LED's and CAPS.
  19. Audioguru
    Dec 20, 2007
    9,411
    896
    My Samsung monitor still works like new. I guess the little Korean kids who built it are teenagers now. I wonder if they are paid more than one bowl of rice per day.
