Fraction of Cycle that Diode conducts
Discussion in 'Homework Help' started by jegues, Mar 17, 2011.
  1. jegues
    Sep 13, 2010
    735
    43
    See figure attached for problem statement as well as my attempt.
    How do we go about calculating the fracion of a cycle for which each diode conducts?
    Thanks again
  2. t_n_k
    Mar 6, 2009
    5,448
    783
    In this case you don't need to calculate anything to work out the diode conduction cycle, since this an ideal full-wave bridge rectifier with a purely resistive load and without any capacitive or inductive filtering applied. Each diode will conduct for one half the AC cycle or 180° electrical.
  3. jegues
    Sep 13, 2010
    735
    43
    But there will still be a small timeframe in which all the diodes are nonconducting(Using constant voltage drop model), i.e. when 0 < Vs < 1.4V and 0 > Vs > -1.4V, correct?
    How do I account for this?
  4. t_n_k
    Mar 6, 2009
    5,448
    783
    If the diodes are non-ideal then that is correct. I now see that's stated in the question.
    On any half cycle the supply must overcome a total drop of 1.4V.
    The secondary supply is 20Vrms or 28.28V peak.
    Solve for the time at which 28.28sinωt=1.4V
    sinωt=1.4/28.28=.0495
    ωt=asin(.0495)=.0495 radians
    t=.0495/ω=.0495/377=131usec
    The diodes will conduct from 131usec after the AC zero crossing to 131usec before the subsequent AC zero crossing.
    One half AC cycle is 8.33msec.
    The total conduction time per diode is then
    16.67/2msec-2*131usec=8.07msec
  5. PerunaPete
    Mar 17, 2011
    22
    Just model the voltage across the diodes with a sine function, and then use an inverse sine to find the value in your calculator. Do note that rms for a sine wave is amplitude/sqrt(2), and don't forget to account for the voltage drop across *both* diodes.
    In the actual output of a regulator, this will look like gaps between the peaks- normally not a concern because a capacitor is typically used.
  6. t_n_k
    Mar 6, 2009
    5,448
    783
    Sorry the secondary would be 12V rms not 20V rms. So you would then re-do my solution using 17V peak rather than 28.28V peak. I'll leave that task to you.
  7. t_n_k
    Mar 6, 2009
    5,448
    783
    As a check - I then get a total conduction time per diode of 7.895msec.
  8. jegues
    Sep 13, 2010
    735
    43
    Wouldn't the RMS for a sine wave be amplitude*sqrt(2)?
    Anyways,
    \theta = sin^{-1}(\frac{1.4}{12\sqrt{2}})
    I'll do both half cycles in one shot,
    2\left( \frac{\pi - 2\theta}{2\pi} \right) * 100 = 94.8% \text{ conduction interval}
  9. t_n_k
    Mar 6, 2009
    5,448
    783
    The question actually asks for what fraction of a cycle each diode conducts.
    A cycle presumably means a complete AC cycle. Therefore I would say the fraction is in relation to a full AC cycle period rather than a half period.
    The correct answer would then be ~47.37%.
  10. jegues
    Sep 13, 2010
    735
    43
    D1, and D2 conduct in the first half cycle, D3 and D4 in the second half cycle, it doesn't specify which diodes in particular so if we consider all the diodes they are conducting 2(47.37%) = 94.74%, right?
    Or is it more like 47.37% each half cycle?
  11. t_n_k
    Mar 6, 2009
    5,448
    783
    At the risk of being accused of pedantry the question asks "For what fraction of a cycle does each diode conduct?" Each diode (not the totality of diodes) conducts only for 47.37% of the AC cycle.
    This is "nitpicking" in the extreme. As long as you can convey your understanding of the physical behavior I wouldn't make a big deal out of which answer is more correct. Consult with your teacher and come to some agreement.
  12. justtrying
    Mar 9, 2011
    329
    407
    knowing the teachers that i have, the correct answer would be 47.37% of the cycle statinging which pair of diodes is conducting during positive half and which pair is conducting during negative half. If you say 94.74%, that implies that all diodes are conducting for full AC cycle, which is not true.
    I'm getting used to the nitpicking, ha ha...
