Fractals in coprime integers
Discussion in 'Math' started by Gerasimov, Sep 18, 2013.
  1. Gerasimov
    Sep 18, 2013
    Greetings, humans! I'm from Ukraine. My English is very bad. So I will use a Google Translate.
    In 2002, I came up with an interesting piece. I was only 14 years old. I was thinking about fractals and chaos theory, and did not want to learn. Did not want to learn, and were forced to walk to school. I came up with a way to kill time on the boring lessons in history, geography, and other humanities. I'll try to explain in detail. All we need - a piece of paper into a cell and an ordinary pencil. If a piece of paper is not available and also no pencil - an online version of JavaScript: http://xcont.com/pattern.html
    The algorithm is simple to indecency. Actually these things look like this:
    Select the rectangle and let in the corner of the "quantum beam" (as I called it in 2002) The beam reflected from the walls and is lost at the other corner.
    If certain conditions were met - it turns fractal pattern.
    If the conditions are not met (for example the obvious - the rectangle are equal) - pattern is not obtained. Of the less obvious example - the same pattern as it is impossible, if the size of the parties have a common divisor. In fact, the patterns are obtained only if the dimensions of both sides - are relatively prime (have no common divisor).
    Сlickable:
    In the picture all the numbers from 1 to 30.
    And now a little about Fibonacci and fractals.
    Patterns represent a fractal.
    What determines the pattern?
    That suggests to us - what if you try to Fibonacci numbers? "Пацан сказал - пацан сделал" (do not know how to translate it to English.
    Painted the largest enclosed area.
    233х144:
    987х610 (pressed 5 times):
    233х144 и 987х610 - identical
    As you can see, fractal repeats part of the overall fractal increased
    Fractals, as they are.
    Site: New kind of fractals - Fractals in relatively prime integers (coprime integers)
    P.S.
    And a little bit schizophrenic 11-year-old:
    Perhaps the chaos - it is also a fractal?
  2. Gerasimov
    Sep 18, 2013
    GIF:
    Сlickable (enclosed area of fractals - "brain slugs"):
    and this :)
  3. Gerasimov
    Sep 18, 2013
  4. studiot
    Nov 9, 2007
    5,005
    515
    Fractals are fun.
