Hi all.. So in looking at LCD displays, I'm thinking my project might be easier to mount in an enclosure if I use a COG (Chip-on-glass) LCD display with an FPC ribbon cable so the PCB can be mounted to the bottom of the box and the display attached via the cable to the top half of the enclosure... To that end, I'm trying to find a mating connector that can be PCB mounted and just plug in the ribbon cable..
The cable in the LCD specs is listed as "27 pins up contact FPC 0.5mm pitch, conductor width 0.3mm".. In checking on Mouser, I see a bunch of 27 contact, .5mm connectors -- some right angle, horizontal mount or vertical.. I'm thinking this item might be what I'm looking for.. Is this a good pair-up?
P.S. The display I'm looking at is a Newhaven shown here...
