foward and reversing motor
Discussion in 'General Electronics Chat' started by neutral83, Jun 14, 2008.
  1. neutral83
    Jun 14, 2008
    hi i am trying to figure out the best way to make a small electric motor go foward then reverse on a constant on position. (like a printer would go back and forth). how would i go about doing this?
  2. hgmjr
    Jan 28, 2005
    9,030
    214
    You will need to use what is called an H-bridge.
    hgmjr
  3. bertus
    Administrator
    Apr 5, 2008
    15,796
    2,384
    In a printer a steppermotor is used.
    By changing the sequence of pulses to the motor the direction can be changed.
    On this page from the EDUCYPEDIA there are links to sites and documents about stepper motors.
    http://www.educypedia.be/electronics/motorstep.htm
    On this site there are more pages with links.
    Motor and generators: Brushless DC motors Motor AC Motor-Synchronous Single phase AC motors Generators Motor DC Robot Stepper motor Generator: asynchronous Motor overview Servomotor Stepper motor drivers
    Greetings,
    Bertus
  4. hgmjr
    Jan 28, 2005
    9,030
    214
    Have you a specific application for your motor in mind?
    hgmjr
  5. thingmaker3
    Retired Moderator
    May 16, 2005
    5,072
    6
    And/or have you a specific motor in mind for your application?
