Fourier transform
Discussion in 'Homework Help' started by ecesoul, Sep 9, 2012.
  1. ecesoul
    Sep 8, 2012
    8
    Given fourier transform H(jw)=(2cosw)(sin2w)/w.
    what is h(0)?
    please help, i think it is a tricky question
  2. WBahn
    Mar 31, 2012
    18,085
    4,917
    We are not mind readers. What do you think is tricky about it?
  3. ecesoul
    Sep 8, 2012
    8
    sorry for the word 'tricky'. It was asked as a multiple choice question in an exam with limited time.So I thought there might be some easier way than conventional.
    I thought about initial value theorem, but don't know whether we can use it in Fourier domain
  4. Papabravo
    Feb 24, 2006
    10,340
    1,850
    Step 1 is to apply the double angle formula
    sin2ω = 2sinωcosω
    Step 2 is to replace the cosine terms with 1 as ω -> 0
    Step 3 is to take the limit as ω -> 0 of sinω/ω which is the well known sinc function, which has a value at ω=0 of 1.
    Step 4 is to write the final answer of 4.
    That's the trick if you can call it a trick.
  5. WBahn
    Mar 31, 2012
    18,085
    4,917
    You can get it even more directly by noting that it can be written as:
    f(w) = g(w) h(w)
    Where
    g(w) = 2cos(w)
    h(w) = sin(2w)/w
    The value of f(w) as w goes to 0 is simply the products of the limits of g(w) and h(w) as they individually go to 0 and, since g(w) is well behaved at w=0 (it's equal to 2), we can focus on h(w).
    This goes to 0/0, which is one of the forms for which we can apply L'Hospital's rule by taking the ratio of the derivatives of the numerator and denominator. which gives us that h(w) as w goes to 0 is 2cos(2w)/1, which evaluates to 2. Taking the product gives us 4.
    Another way is to recall that, for sufficiently small angles, sin(theta) is approximately (theta). Well, approaching zero certainly qualifies as 'sufficiently small', so sin(2w) is about 2w, giving us:
    f(w) = 2cos(w)(2w/w) = 4cos(w) for small w. For w approaching zero, this approaches 4.
  6. ecesoul
    Sep 8, 2012
    8
    Sorry I think you missed an important point
    H(jw) is given ie in frequency domain
    But we have to find h(0), which is Limit t->0 h(t) ,this is in time domain
    So we have to find inverse transform, I dont know how that could be done in this case
  7. WBahn
    Mar 31, 2012
    18,085
    4,917
    You're right. I thought you were looking for H(0), not h(0). My vision is getting blurry enough that I have a hard time telling the difference between h and H. I got focused on the removable singularity and thought that was what wa giving you problems.
    Now your comment regarding the initial value theorem makes much more sense. I'm not sure whether you can apply it or not. I thought you probably could, but haven't been able to confirm that and have seen some things that imply you can't. This makes sense because the Fourier transform is for periodic signals that exist for all time, so the very notion of an 'initial' or 'final' value is problematic.
    Now, given a Laplace transform, you can convert it to a Fourier transform by setting s=jw. Depending on whether information was irretrievable lost in that process, you might be able to get the Laplace transform back by setting w = -js. But I'm skeptical that this is going to be valid.
    Sorry I don't an answer or even firm guidance for you, but hopefully something I've said will get you to looking in a direction that eventually leads to someplace worthwhile.
  8. Tesla23
    May 10, 2009
    323
    67
    given
    h(t)=\frac{1}{2\pi}\int H(\omega)e^{i\omega t}d\omega
    then
    h(0)=\frac{1}{2\pi}\int H(\omega)d\omega
    you need to do some trigonometry on H(\omega) to evaluate this using some standard integrals
