Fourier Transform
Discussion in 'Homework Help' started by smarch, May 9, 2010.
  1. smarch
    Thread Starter Active Member
    Mar 14, 2009
    52
    [​IMG][​IMG]Hi
    I am trying to find an expression for X(f), when,
    x(t)=exp(-σt)sin(2∏f1t)
    I have attached a screen shot of what I have worked out, but it doesn't seem to be coming together very vell, is there something I am missing in the steps? Or am I right, and how would I integrate that?
    thanks.
  2. t_n_k
    Mar 6, 2009
    5,448
    783
    The Fourier transform of
    u(t)\epsilon^{-\sigma t}sin(\omega_{1}t)
    per table of transforms is
    \frac{\omega_{1}}{\omega_{1}^2+(\sigma+j\omega)^2}
    The u(t) bit tells you the limits of integration are from 0 to plus infinity - otherwise there is no solution if the lower limit goes to minus infinity . The problem can be solved using repeated integration by parts.
    Not sure if this is the same as your problem - given your equation has no reference to the u(t) term - i.e. the Heavyside Function.
  3. smarch
    Mar 14, 2009
    52
    Thanks for your reply,
    I have attached another JPEG, I have come up with an expression but not sure if it is correct, I did mean to put the limits from 0 to infinity sorry about that.
    However, when i put this into matlab to plot the X(f), i just comes out wrong.
  4. t_n_k
    Mar 6, 2009
    5,448
    783
    This is my method ...
