fourier transform basic confused
vead
Joined Nov 24, 2011
629
hi everyone
i am just begin to learn about Fourier transform
i know Fourier transform is used to analysis of signals such as Rf signal
which convert time domain to frequency domain
for example
f(t)=sin15πt
how to know signal is periodic or aperiodic
how to take Fourier transform of this function
i am trying to learn how time domain is converted in to frequency domain
please someone explain with simple trick
thanks for every help
Zazoo
Joined Jul 27, 2011
114
A periodic signal repeats at regular intervals (an aperiodic signal does not.)
For a transform there isn't really a "simple trick" as there is a lot of theory behind the transform itself and how the two domains relate to one another.
There are, however, Fourier transform tables which list transforms for common functions.
thatoneguy
Joined Feb 19, 2009
6,359
Your equation, \(sin\omega_0t\) is halfway down the second page of the PDF linked above.
So if there is an FFT for it (though too long for me to type in right now), do you think that means it is periodic or transient/aperiodic? Look at the FFT of your function and decide if there is a constant, or something that will settle to a steady state.
