Fourier series
Discussion in 'Homework Help' started by ericyeoh, Oct 9, 2011.
  1. ericyeoh
    Thread Starter Active Member
    Aug 2, 2009
    58
    Guys,
    Need guidance from u guys, if question given determine all then non-zero fourier coefficient in a periodic function f(t) = 5 +cos^2 (t) V.
    Should i start to integrate the function from -infinity to infinity?
    F(t) = A0/2 + Intergrate ( an cos wt + bn sin wt) ?
  2. t_n_k
    Mar 6, 2009
    5,448
    783
    Keep in mind that one may re-write
    cos^2t=\frac{1+cos2t}{2}
    using the known trig identities.
    Make the substitution for the cos^2t term into the given f(t).
    Henceforth your problem in finding the non-zero Fourier series coefficients reduces almost to a solution by inspection.
