Fourier Series
Discussion in 'Math' started by RdAdr, Oct 18, 2015.
  1. RdAdr
    May 19, 2013
    214
    Consider the following article:
    https://en.wikipedia.org/wiki/Fourier_series
    At definition, they say that an = An*sin() and bn = An*cos()
    So with these notations you can go from a sum having sin and cos to a sum having only sin but with initial phases.
    Why can I write an = An*sin() and bn = An*cos() ?
    It seems out of the blue.
  2. RdAdr
    May 19, 2013
    214
    I figured it out. It follows from Pythagora's theorem in a right angle triangle.
  3. Motanache
    Member
    Mar 2, 2015
    109
    5
    It is not that difficult.
    Look at this figure:
    In the first image we have square signal.
    But a radio device receives a sine wave.
    LC oscillate as Sin():
    https://en.wikipedia.org/wiki/RLC_circuit
    So in the first image signal approaches with Sin() drew orange.
  4. Motanache
    Member
    Mar 2, 2015
    109
    5
    It is the main component of which will receive a radio, if you give a rectangular signal as in the first image.
    In fact, RLC react to a growth rate (di/dt):
    And the margins are 'very steep', that means I had very high frequency component.
    So, what I could add up to that SIN ()(orange line) to drown the steep edges? corners.
    This is the case sinusoids of blue and green.
    Because we can not hatching the entire rectangle so, something must also substracted. Therefore we have cosine.
  5. Motanache
    Member
    Mar 2, 2015
    109
    5
    Forming a rectangular signal from sine signal:
  6. RdAdr
    May 19, 2013
    214
    Thanks for the answers.
