Fourier series, please help!!
Discussion in 'Homework Help' started by calcgirl, Jun 8, 2008.
  1. calcgirl
    Jun 8, 2008
    I am having a difficult time finding the fourier series for (sin x)^2.
    I am aware that I have to use the trig identity:
    (sin x)^2=1/2-1/2(cos 2x) but I don't know where to go from here. ANy help would be greatly appreciated thanks!!
  2. silvrstring
    Mar 27, 2008
    159
    Are there any limits (e.g., 0<=x<=1, or 0<=x<=2pi)?
    I'm gonna guess 0<= x <= 2pi.
  3. calcgirl
    Jun 8, 2008
    No limits are given in the problem but when looking at the graph it cycles every pi.
  4. silvrstring
    Mar 27, 2008
    159
    Then you're using 0<=x<=2pi.
    I'll see if I can come come up with something on paper to scan.
  5. silvrstring
    Mar 27, 2008
    159
    Calcgirl, I can't come up with an example without having to do your problem.
    Are you having a problem understanding how to solve a Fourier series problem, or are you having a problem integrating int((sin(x))^2 * cos(kx) dx) or int((sin(x))^2 *sin(kx) dx)?
  6. calcgirl
    Jun 8, 2008
    I understand how to do a typical fourier series problem such as if the function was a piecewise or the function x^2. But I was told that this problem can be used without any integration and that the double angle formula/trig identities were to be used. I guess I just don't know what else to do after I have my new equation:
  7. Ratch
    Mar 20, 2007
    1,068
  8. silvrstring
    Mar 27, 2008
    159
    Wow. Okay.
    Are you sure you have to solve this for a Fourier series; I don't think it is possible, because the constant k in cos(kx) and sin(kx), will ruin the process when integrating. This happens whether you use double angle ids, or not.
    The average is visually 1/2, and (1/2pi)int((sinx)^2) dx) equals 1/2. If your instructor told you integration need not be used, I'm wondering if he meant a Fourier series solution was needed at all. Even substituting a Taylor polynomial to the nth degree for sin^2(x) will not work.
    Mark44 and hgmjr might be able to help. If not, I'll get back to you tomorrow.
    Post if you figure it out.
    Take care, and Welcome.
  9. Mark44
    Nov 26, 2007
    626
    A Fourier series is an infinite series involving terms in sin(nx) and cos(nx). Since one part of the function you're working with is 1/2 cos(2x), you're halfway home to your answer, meaning that the Fourier series for 1/2 cos(2x) is just 1/2 cos(2x). All you need to do for your problem is to find the Fourier series for 1/2.
    You also need to know the interval over which to integrate, which you haven't mentioned, so I'm going to assume that it is [-pi/2, pi/2]. If it's a different interval, let me know, since the work that follows is using this assumption.
    Now, because the function you're working with is even, there aren't going to be any sine terms. The series will look like this:
    1/2 = a_0 + summation[a_n cos(2nt)], with the summation running from n = 1, 2, 3, ....
    Here are the coefficients:
    a_0 = 2/pi * integral[1/2 dt], integrated between 0 and pi/2
    a_n = 4/pi * integral[1/2 cos (2nt) dt], integrated between 0 and pi/2, and for n = 1, 2, 3, ... You should be able to evaluate the integral one time for any value of n, and get an expression for a_n.
    Calcgirl, see if this works for you. If you have problems, reply back.
    Mark
  10. silvrstring
    Mar 27, 2008
    159
    I think this might help. I attached it. Maybe your instructor wanted you to see that the trig identity could be proven with Fourier series.
    You wouldn't know that you didn't need to integrate until after you did it, though; You didn't need to do anything for that matter. I guess he was hinting that the identity is in Fourier series form already.
    All a(k) and b(k) after the work shown were 0.
    Take care.
  11. Mark44
    Nov 26, 2007
    626
    Silvrstring,
    Looks good to me. When I posted my reply earlier today, it completely escaped me that 1/2 - 1/2 cos(2x) already was a Fourier series. Doh!
  12. silvrstring
    Mar 27, 2008
    159
    Yeah, me too! I hate when they play those games!
