Fourier Series in Circuit analysis
Discussion in 'Homework Help' started by Hanck, Dec 27, 2008.
  1. Hanck
    Nov 25, 2008
    The question given Vs = 1/2 + (2/pi)Ʃ(1/2)cos(n*pi*t - 90°)
    i cannot figure out why when nth harmonic
    Vs = (2/[n*pi])cos(n*pi*t - 90°) = (2/[n*pi]) polar -90°
    The lecturer told me just simply take the θ in cosine term [cos (wt-θ)] as the angle in polar coordination but i still cannot understand why...
    If it is simply like that then why
    given Vs = 1 + Ʃ [2*(-1)^n / (sqrt (1 + n^2))]* (cos nt - n sin nt)
    for nth harmonic
    Vs = [2*(-1)^n / (sqrt (1 + n^2))]* polar arctan n
    why arctan n?
    I appreciate any help, thanks.
  2. DrNick
    Dec 13, 2006
    convert the second formula you gave into it's complex form. That will make things clear.
    (complex form being f(t) = sum(Ck*exp(-j*w*n*t))...)
    Also, If you do compute the complex form you will find that the solution for your n'th harmonic is incorrect.
    Vs = [2*(-1)^n / (sqrt (1 + n^2))]* polar arctan n , should be
    Vs = [(-1)^n]* polar arctan n
    when changed to complex form you get
    and 1-j*n = sqrt(1+n^2)*exp(j*atan(n))
    when you perform the multiplication
    f(t) = sum(bn/(2*sqrt(1+n^2)*exp(-jwnt+atan(n)))
    in your case bn = 2*(-1)^n / (sqrt (1 + n^2))
    SO, f(t) = sum((-1)^n*exp(-jwnt+atan(n))). Note this is summed from -inf to +inf. this means the nth harmonic should be (as stated above) (-1)^n polar atan(n).
    NOTE: please check my seems right to me, but there may be some lame error. long story short, this explains the atan(n)...
