Fourier series coefficients
Discussion in 'Homework Help' started by whoozit, Feb 25, 2008.
  1. whoozit
    Feb 25, 2008
    Here is a problem I'm having trouble with. (Please remember that I am new at this.) Any help is much appreciated.
    Consider the following three continuous-time signals with a fundamental period of T = 1/2
    x(t) = cos(4*pi*t)
    y(t) = cos(4*pi*t)
    z(t) = x(t)y(t)
    a) Determine the Fourier series coefficients of x(t).
    b) Determine the Fourier series coefficients of y(t).
    c) Use the results of parts a and b along with the multiplication property of the CT Fourier series to determine the Fourier coefficients of z(t).
    d) Determine the Fourier series coefficients of z(t) through direct expansion of z(t) in trig form and compare that with the results of part c. (I'm guessing they will be equal.)
    What I have so far:
    I think I have to use these trig identities.
    Also, I know the definition of the fourier series coefficients a0, an, and bn.
    x(t) = a0 + \suman\timescos(2\timespi\timesn\timest/T) + \sumbn\timessin(2\timespi\timesn\timest/T)
    Aside from that, I'm pretty much lost. Any suggestions?
  2. scubasteve_911
    Dec 27, 2007
    1,202
    You just use Euler's identity and factor out the coefficient. So, your Cn value is of magnitude 1/2 at + and - 4pi.
    For the next part, you can add the exponential coefficients together.
    Steve
    attached is an old assignment i had to do lastyear, which may help you understand, or confuse you, either way.
  3. Dave
    Retired Moderator
    Nov 17, 2003
    6,960
    146
    x(t) = y(t):
    Is that correct given that your question asks:
    As written they would obviously have the same coefficients. This has implications for later in the question so it is worth clarifying this point now.
    Dave
