fourier / convolution
Discussion in 'Homework Help' started by hamza324, Nov 22, 2011.
  1. hamza324
    Jul 10, 2011
    33
    HI
    My prof gave a question
     x= \delta(t-1) + 5Cos(2t) \ \ \ \longrightarrow \ \ \ \ \ \fbox{H( \omega)= \frac {1}{j\omega +1}} \ \ \ \longrightarrow \ \ \ y=find \ using \ super \ position
    Now for the solution , he treats each of the input functions separately with the boxed function.
    he writes
     x_1 = \delta(t-1) \longrightarrow \fbox{h(t)=e^{-t} u(t)} \longrightarrow h(t-1)=e^{-(t-1)}u(t-1) = y_1
    Then,
     x_2 = 5Cos(2t) \longrightarrow \fbox {H(\omega)=\frac{1}{j\omega+1}} \longrightarrow 5\   \mid H(\omega)\mid \ Cos(2t + \theta)
     where \mid H(\omega) \mid=( \frac{1}{(2)^2+1})^{\frac{1}{2}}and \theta =- tan^{-1} ( \frac{2}{1})=-63^o
    So using super sposition , we get
     y(t)=\  e^{-(t-1)} u(t-1)\ \ \  + \ \ \ \frac{5}{\sqrt{5}} Cos(2t-63^o)
    Now my question is that,
    1 - Why did he used time domain for the impulse function and frequency domain for cos(2t).
    2 - How did he get expression for y_2 , the one with magnitude of H(w).
    thnx
  2. steveb
    Jul 3, 2008
    2,433
    469
    For question 1, one is free to use either the frequency domain or them time domain, depending on which is easier. Note that the first input is a delayed impulse function, so the output of that will be a delayed impulse response. So, he transforms the H(w) of the system and then delays the time domain impulse response function.
    For question 2, he simply noted that H(w) is the frequency domain response and the input is a pure cosine wave, with frequency 2 and no phase delay. So, he can quickly calculate that the output will be scaled in magnitude and phase shifted by using H(w).
  3. hamza324
    Jul 10, 2011
    33
    Thanks for explanation.
    I have another similar question regarding discrete time
    I have an expression
     e^{j \Omega n} \longrightarrow \fbox{h[n] \longleftrightarrow H(e^{j \Omega})} \longrightarrow H(e^{j \Omega}) e^{j \Omega n}
    I know this is frequeny response but i dont understand the expression at the output
    Can you please provide me with some simpler explanation for this expression and some kind of example if possible.
  4. steveb
    Jul 3, 2008
    2,433
    469
    This is similar to the analysis of the second component of the input signal above (i.e. the 5cos(2t) part). That example was a continuous time cosine wave going through a system with known frequency response.
    This problem is pretty much the same, only it is a complex sine wave, and the problem is in discrete time.
    For background, in continuous time the frequency response is obtained by taking the Laplace s-domain transfer function H(s), where s=\sigma+j\omega, and substituting s=j\omega, which puts you on the jw-axis. In discrete time, the frequency response is obtained by taking the Laplace z-domain transfer function  H(z), where z=r\; {\rm e}^{j\Omega}, and substituting  z={\rm e}^{j\Omega}, which puts you on the unit circle.
    hamza324 likes this.
