four bit arithmetic unit
Discussion in 'The Projects Forum' started by iseeu, May 22, 2008.
  1. iseeu
    May 22, 2008
    hi there,
    I have a question which is in regards to computer system architecture and i am stuck. I need some help and it would be greatly appreciated in producing a circuit of a simple four bit arithmetic unit that can add or subtract two 4 bit binary values. Although only four-bit device is required, the design is expected to be easily extended to any word size.
    I am using the digital works application to design this.
    thanks in advance
  2. mik3
    Feb 4, 2008
    4,846
    63
    Check this website for some information :
    http://www.parl.clemson.edu/~dstanzi/201lab/lab5.html
    You can extend this 4-bit adder/subtractor by adding more full adder stages and XOR gates.
    If you want more information type adder/subtractor circuit in google
  3. iseeu
    May 22, 2008
    thanks very much for the help really appreciate it
  4. iseeu
    May 22, 2008
    what if i were to want to modify it and add extra circuitry to enable the ALU to perform multiplication and division. i have found it quite difficult finding information on the multiplication and especially the division any help would be greatly appreciated.
  5. beenthere
    Retired Moderator
    Apr 20, 2004
    15,815
    283
