FOSC2:FOSC0 Settings for PIC16F819
Discussion in 'Embedded Systems and Microcontrollers' started by ronbowalker, Nov 18, 2009.
  1. ronbowalker
    Jun 26, 2009
    23
    Below is a ticket I processed with Microchip on this issue. As well as the response I got. I am not familiar with the info (FOSC2:FOSC0) they gave me and need assistance in writing this in PBP. I have found that 31.25kHz is defined as "100" on the datasheet. I am also using INTIO2 on the programming configuration, making pins 6 & 7 as I/O ports.
    Description:Using Pic Basic Pro as programming tool:
    I am trying to initialize the 16F819 for:
    Pins A.0, A.1, A.3, B.0, B.1, B.2, B.3, B.4, B.5 to be OUTPUT/LOW (Digital).
    Pins A.7 and B.0 to be OUTPUT/HIGH (Digital).
    Pins A.6, B.6, A.2, A.4 to be input pins.
    I am also wanting to configure the OSC to be 31.25kHz internal. What configuration settings do I use for this?
    Resolution:I'm not familiar with Pic Basic Pro but the registers that need to be configured for the I/O are below.
    TRISA
    TRISB
    PORTA
    PORTB
    OSCCON
    ADCON1
    The MCLR pin configuration will depend on how you want to use the Pin. If you want to use it as an input you need to clear the MCLRE bit in the configuration bits register. Otherwise if it is to be used as a reset the MCLRE bit must be set to a 1.
    If you want to use the Internal Oscillator as your primary clock you need to have the Fosc2:Fosc0 bits in the configuration bits register programmed as 100.
    Here is the program I am using, and I get no HIGH outputs. Assistance would be greatly appreciated.
    DEFINE OSC 3
    OSCCON = %00001000
    ADCON1=7
    TRISA = %01110100
    TRISB = %10100000
    PORTA.0 = 0
    PORTA.1 = 0
    PORTA.3 = 0
    PORTA.7 = 1
    PORTB.0 = 1
  2. eng1
    Oct 25, 2009
    13
    I can't help with basic, but you must tell the compiler that you want to use the internal oscillator. As suggested, you have to configure bits Fosc2:0 bits of the configuration word.
    You can probably do that manually in the programming enviroment (not recommneded) or do it in code through @device at the beginning of your program, I guess. Google can find more information on this topic.
  3. ronbowalker
    Jun 26, 2009
    23
    I have been trying to find the answer on a lot of different forums, but still nothing. Thanks for the assistance.
    A lot of people are viewing this call for help, but none are responding!
  4. BMorse
    Sep 26, 2009
    2,675
    234
  5. AlexR
    Jan 16, 2008
    735
    54
    As eng1 stated to use PIC's the internal oscillator you have to set the configuration word (also sometimes referred to as the fuse settings). This is not one of the normal SFR's and it requires its own special command.
    Unfortunately the command to set the configuration word does not exist in PBP so the work-around is to issue the command as a line of embedded assembler code. The issue is further complicated by the fact that PBP can be set up to either use its native assembler (PM) or Microchip's MPASM assembler and the commands are not the same in the two assemblers.
    In PM the command to use the internal oscillator would be:
    @ DEVICE pic16f819, INTRC_OSC
    The "@" signifies assembler code, "DEVICE" tells the assembler to load the config word, pic type indicates where and INTRC_OSC is the value. The actual values are in the pic16f81X.inc file. If you want to set several paramaters at the same time just seperate them with commas, eg @ DEVICE pic16f819, INTRC_OSC, WDT_OFF sets oscillator to internal and turns off the watchdog timer.
    If you are set up to use MPASM then the command would be
    @ __config INTRC_OSC
    Or for muliple statments just and them as: @ __config INTRC_OSC & WDT_OFF
    Note the double underscore at the beginning of the config command!
  6. ronbowalker
    Jun 26, 2009
    23
    Thanks for the help and sorry for the slow reply....I went on holiday and just got back. I followed your suggestions and here is what I found to apply to my PBP assembly.
    The following compiles correctly:
    @__Config_INTIO2_OSC
    @__Config_WDT_ON
    This gives error message "Error[108]:Illegal Character (&)" :
    @__Config_INTIO2_OSC & WDT_OFF
  7. ronbowalker
    Jun 26, 2009
    23
    FOSC settings in PBP is what I do not know correctly.
    OSCCON $00000000 works fine and the chip is running @ 85uA.
    I have config settings (INTRC INTRIO2) and the pins 6&7 seem to be outputs now.
    But LED does not blink:
    DEFINE OSC 3
    OSCCON = %00000000
    ADCON1=7
    TRISA = %00000000 'Outputs
    TRISB = %00000000 'Outputs
    PORTB.4 = 0 'Pin 10 Low
    LOOP:
    PULSOUT PORTB.4,20 'pin 10 Pulse LED
    Pause 20
    Goto LOOP
