EPHY SWITCH output is connected to LAN ports. It is the same if we connect Wireshark analyzer to regular LAN port. But data on the LAN ports does not contains a full Docsis packets.Use the four port switch, labeled "EPHY SWITCH" in the block diagram.
I understand we need encapsulate raw DOCSIS packets in Ethernet framing, where "Ethernet framing" refers to the very low-level framing that marks the start and end of an Ethernet frame, not to Ethernet link-layer headers. The question is how to implement this encapsulation.The only place you'll be able to tap off DOCSIS is between the tuner and the MAC/PHY chip, the signals labeled US and DS. You won't be able to connect a LAN port, however, because LAN uses Ethernet protocol, not DOCSIS. If you want to sniff DOCSIS packets, you'll need a port that speaks DOCSIS protocol.
Negative. You would need all the Data Link information to be included.I understand we need encapsulate raw DOCSIS packets in Ethernet framing, where "Ethernet framing" refers to the very low-level framing that marks the start and end of an Ethernet frame, not to Ethernet link-layer headers.
You would need an Ethernet MAC/Phy chip to connect to your DOCSIS data. Most likely, you'd need to do some processing between the chip and your modem. Exactly what processing, I don't know at this time.The question is how to implement this encapsulation.
If you have that facility, then just use it. If not, you might be out of luck.Cisco enterprise routers, like uBR7200 series with Cisco IOS software, provide this option with cable monitor command, that forward copies of full DOCSIS packets to an external LAN analyzer attached to another Ethernet port on Cisco router. Or it can strip the DOCSIS headers and forward only the Ethernet frames. Very handy in troubleshooting network and application problems.
It's possible. Only your device's documentation or a call to tech support will tell.If implement encapsulation is problematic, it is possible dump full Docsis packets and save it in a capture file, for offline analysis?
Thread starter | Similar threads | Forum | Replies | Date |
Understanding forwarding unit | Homework Help | 0 | ||
D | Ethernet "test" its connected and can pass packets. | Test & Measurement | 8 | |
B | Sniffing packets from chip CC1350 | Wireless & RF Design | 9 | |
S | Receive packets and read routine ENC28J60 | Microcontrollers | 0 | |
M | forwarding ? | General Electronics Chat | 2 |
by Aaron Carman
by Jake Hertz
by Duane Benson
by Aaron Carman
