forward voltage drop
Discussion in 'Homework Help' started by prejval2006, Oct 25, 2006.
  1. prejval2006
    Oct 25, 2006
    21
    i want to know exact defination of forward voltage drop when diode is forward biased please explain in detail.
  2. pebe
    Oct 11, 2004
    628
    Quite simply, it's the voltage difference between anode and cathode of the diode, due to the diode passing current.
  3. Papabravo
    Feb 24, 2006
    10,338
    1,850
    There are three progressively more complicated models of a diode.
    1st Model(ideal diode) -- On a plot of current(I) vs. voltage(V) imagine a horizontal line at I=0 from minus infinity up to Vf = 0.7 Volts. At this point imagine a vertical line at Vf = 0.7 Volts from the horizontal axis off to infinity.
    2nd Model(linear approximation) -- Same line from V = minus infinity to Vf = 0.7 Volts. Now instead of a vertical line draw one from Vf = 0.7 Volts with a very steep slope of to (V, I) = (inf, inf)
    3rd Model(exponential approximation) -- Same line from V = minus infinity to V = 0.5 volts and now fit an exponetial curve at that point which goes off to infinity.
    It is in this third model we can see that the diode begins to conduct some current at a voltage that is lower than the forward voltage in operation. If we try to raise the voltage a little bit the the diode will conduct much more current as the voltage goes from 0.5 to 0.7 volts.
    This is why you often see a diode, especially an LED, in series with a resistor.
    This story ignores the extreme conditions that will cause device failure from either too much reverse voltage or too much current while forward biased.
  4. hgmjr
    Jan 28, 2005
    9,030
    214
    It is probably worth noting that the modeling that papabravo has described is that of a silicon diode.
    There are diodes constructed from the semiconductor material germanium that have the same basic modeling that papabravo has outlined but differ in the value of the voltage at which the knee occurs. I believe the generally accepted value for this voltage is around 0.2 volts. These diodes are not very widely used any longer as they tend to exhibit greater variations in their forward bias voltage due to temperature than the silicon based diodes.
    hgmjr
  5. Papabravo
    Feb 24, 2006
    10,338
    1,850
    There are also Schottky diodes which have a threshold in 0.2 to 0.3 Volt range. There are many types of diodes which are customized for different applications. It is a very versatile component.
  6. pebe
    Oct 11, 2004
    628
  7. hgmjr
    Jan 28, 2005
    9,030
    214
    That is a good point.
    At the risk of dating myself, I recall the day when selenium rectifiers were all the rage. I believe the drawback to these devices were that selenium was toxic.
    hgmjr
  8. pebe
    Oct 11, 2004
    628
    .....and smelled of old boiled cabbage! :)
  9. prejval2006
    Oct 25, 2006
    21
    thank you papabravo
  10. Papabravo
    Feb 24, 2006
    10,338
    1,850
    You're welome
  11. Lebe
    Sep 16, 2008
    so basically when one uses the term "forward voltage" it is the same as voltage drop?
    forward voltage = voltage drop?
