Forward converter design - current through switching MOSFET
rochak.chadha
Joined Mar 17, 2012
7
Hi everyone,
I am a newbie here so apologizes if I miss something. I am designing a forward converter and I am simulating the circuit in PowerSim. What I am surprised to see is that the current through the MOSFET switch is about 3 times the output current of the converter. Although, the converter is providing the required output current, but it seems weird if so much current is just being 'burnt' via MOSFETs resistance.
I am using an application note by On Semi for the design, here is the link to the pdf http://www.onsemi.cn/pub_link/Collateral/NCP1216AFORWGEVB_MANUAL.PDF
Will be grateful for your help folks,
Thanks !
Rochak
bountyhunter
Joined Sep 7, 2009
2,512
In a forward conv, current flows in the primary and secondary of the transformer at the same time. You should be able to calculate the currents based on the output side current and the transformer turns ratio. Make sure your simulation has the correct turns ratio. This design has a max duty cycle of only 50%, so the peak currents on the primary will be high since the transistor only works half the time.
rochak.chadha
Joined Mar 17, 2012
7
Thanks BountyHunter, I checked the turns ratio and it is fine. The primary: tertiary winding's ratio is 1:0.8 and while primary to secondary ratio is 1:1.78. This does mean that the current in the tertiary winding will be high and so the current in the MOSFET.
Is this a correct conclusion ?
The transformer is a commercial coilcraft product, designed for 30W applications
Here is the link to the product page http://www.coilcraft.com/fct1xxd3sl.cfm
The part number is FCT1-240D3SL.
Thanks for your help !
Rochak
