formula for parallel circuits
Discussion in 'General Electronics Chat' started by Michele, Nov 29, 2005.
  1. Michele
    Nov 29, 2005
    If the total circuit dissipation is 1.44 Watts on a three branch parallel resistor and branch 1 is half the current value of branch 2 and one third the current value of branch 3; v applied to the circuit is 120V.
    What are the v, i, r, and p values for the circuit and for each branch
  2. hgmjr
    Jan 28, 2005
    9,030
    214
    Total R of the circuit is V^2/R = (120*120)/1.44 or 10,000 ohms
    Total I of the circuit is V/R = 120/10000 = 0.012 Amps
    These are the starting points. Everything else proceeds from these values.
    hgmjr
  3. JoeJester
    Apr 26, 2005
    3,393
    1,211
    Michelle,
    Draw your circuit and get into the habit of constructing a table like the one I attached illustrating for your problem.
    Fill in the knowns and think about the problem.
  4. HEALEY
    Nov 10, 2004
    5
    [attachmentid=995]
    HOPE THE ATTACHMENT HELPS - CHECK LIBRARY FOR ELECT ENGRG BOOK WITH KIRCHOFF'S LAWS
    SHOULD EXPLAIN MY LOGIC IN ATTACHMENT[attachmentid=995]
  5. HEALEY
    Nov 10, 2004
    5
    Sorry- there is an incorrect value in the attacment I transmitted earlier - new attachment adds a comment with the correct value
  6. HEALEY
    Nov 10, 2004
    5
    Again my apologies - comment did not appear - try this one
